1971 DT1E head lamp
  • msavitt
  • msavitt's Avatar Topic Author
1971 DT1E head lamp was created by msavitt
Hi and Low beams toast and config way different that my 360 for which I have a spare.
see pictures - the bulb that’s larger than the hole comes lose when I bend the 6 tangs so it cannot be removed so I am assuming this isn’t serviceable?
any suggestions how I could pop a new bulb into this?  Or any other ideas?
thanks
martin
thanks
martin
30 Apr 2021 14:02 #1
Replied by 1971DT250 on topic 1971 DT1E head lamp
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=324577442759&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • msavitt
Replied by msavitt on topic 1971 DT1E head lamp
thank you
30 Apr 2021 15:34 #3
Replied by apex on topic 1971 DT1E head lamp
I walked through a process to install a replacement bulb in the original lens on this thread:
www.yamaha-enduros.com/index.php/forums/...requires-work#113216
To this day, it works just fine. This was installed on an orig DT1E lens, FYI.
Allrighty Then
30 Apr 2021 22:13 #4
  • msavitt
Apex - thank you. I literally just ordered same bulb to stuff into old sealed beam minus busted out old bulb
once I get this and magneto sorted it’s time to ride!
thsnk you
The following user(s) Liked this Post: apex
30 Apr 2021 22:30 #5
