what's the trick?
Replied by RT325 on topic what's the trick?
Street legal DT1MX. Like to see a pic of that sometime. Is the power annoying around town--either under where it makes good power or in the power & saying "come on let's go"!!
Sorry thought this was going to insert with the post from Rick C. I should've used Quote button i guess.
Last edit: 14 Apr 2021 15:51 by RT325.
14 Apr 2021 15:49 #11
  • msavitt
  • msavitt's Avatar Topic Author
Replied by msavitt on topic what's the trick?
No offense taken, many people including my wife question my mental capacity.
But yes on fully forward. However i did buy a new used pair of tensioners since the last ones were ground as think as American cheese so I even flipped these down just in case.
Will take another shot later tonight. Wondering if a warmed up new chain which seems to be coated in paraffin like lube might be help.
14 Apr 2021 19:34 #12
Replied by Swoop56 on topic what's the trick?
It looks like my parts book for the DT1 E has an error .
Not completely unusual . I made an error though with the chain .
As you can't get the new chain to connect with the wheel pushed
completely forward , you obviously need a longer chain .
The DT1 E had a longer swingarm than the earlier 250's .
Pushing the wheel completely forward loses some of the advantages
of the longer swingarm .
If you decide to replace your rear sprocket , you could use one a tooth less
and then your chain will fit .
14 Apr 2021 23:49 #13
  • msavitt
that's cool swoop56, i think i might get a longer chain and see where i end up with 103 links....I suspect after a short amount of time i may be taking a link out, or not
15 Apr 2021 09:28 #14
You may get a blank stare if you ask for a 103L chain .
They come in even number increments .
So you should  be looking for a 104L item .
Perhaps you should count the number of links on your
current replacement chain , to see if it actually has as many links
as it was supposed to have ( don't forget to include joiner link ) .
15 Apr 2021 13:23 #15
Replied by Schu on topic what's the trick?
My little DT100 came with a new chain in the box which was too short, so I bought an offset half link and it fit fine. Half links will wear out faster than a standard link, but probably not in my lifetime.
15 Apr 2021 17:06 #16
  • msavitt
Amazon prime - exchanging for 120 and will cut as needed
thanks!
15 Apr 2021 18:58 #17
