AT1C starter/generator help
- yamahahaha
AT1C starter/generator help was created by yamahahaha
I'm not familiar with this model. Can you guys tell me from just a photo what issues you see here. TIA
20 Feb 2021 15:29
- Mothersbaugh
Replied by Mothersbaugh on topic AT1C starter/generator help
Looks like an AT-1 125 model. At the very least, clean up the spring loaded advance mechanism there at the end of the crankshaft and make sure the points are set at spec, .015", I think.
20 Feb 2021 16:12
- yamahahaha
Replied by yamahahaha on topic AT1C starter/generator help
Can someone tell me what are the 3 or 4 brown looking pieces between the terminals from left to right ???
21 Feb 2021 06:39
- Swoop56
Replied by Swoop56 on topic AT1C starter/generator help
It's the same fibre insulating material that keeps the wiring terminals electrically separate .
The following user(s) Liked this Post: Rick C., MarkT
- yamahahaha
Thanks swoop56. Do you see anything that is not correct from a visual point?
21 Feb 2021 13:10
Replied by MarkT on topic AT1C starter/generator help
Picture is hard to see... are points connected to green at junction block?
Pretty sure they should be connected to orange?
21 Feb 2021 13:26
- yamahahaha
hmmm
21 Feb 2021 13:35
It's really hard to see... could be okay.
My question is why are you even asking? What's wrong with the bike? Symptoms?
Or is just this something you are thinking of buying?
21 Feb 2021 15:58
- yamahahaha
Thinking of buying
21 Feb 2021 18:33
Wires are probably fine. Starting advance (governor) is corroded but at least it's there as it can be expensive to find one. Important part because it has the points cam.
Requires 12v battery for spark. Is a generator/starter that may or may not work. Brushes can be expensive and may be required. Not too hard to troubleshoot using the manual. Rest of electrical is easy because it all runs off battery.
21 Feb 2021 18:55
