Technical Bulletin M4-101
  • Bore Monger
  • Bore Monger's Avatar Topic Author
Technical Bulletin M4-101 was created by Bore Monger
Looking for Technical Bulletin M4-101. Transmission gear update for 1970 DT1CMX. Thanks in advance.
1968 DT1
1969 CT1
1969 DT1
1970 CT1
1971 CT1
1971 DT1
1972 DT2
1973 SUZUKI RV125 (2)
14 Jan 2021 20:41 #1
Replied by Rick C. on topic Technical Bulletin M4-101
Did you try the tech library up above?
And it could be hidden at the end of some of the DT manuals.
ouch, upgrade to site is a bugger, maybe you can find it.
______________________________________
edit again- Just got this ...
Website Problems (Today)
We are working on several current website issues. I think I have the slowness addressed. There is a template issue that is causing some error messages. Working on a fix. The messaging is still not working, but our vendor is trouble shooting that. I hope to have all of these issues fixed in short order. There may be some additional slowdown on the site if we need to do more debugging, as that process uses server resources.
We will get this sorted as quickly as we can - Thank you for your patience.
Mako
Last edit: 14 Jan 2021 21:14 by Rick C..
14 Jan 2021 20:58 #2
Replied by MarkT on topic Technical Bulletin M4-101
M4-101 is a bulletin for the standard DT/RT Enduro transmissions only. It does not apply to the close ratio transmissions used in some DT/RT Enduros and MX models.
14 Jan 2021 21:24 #3
Replied by JGersh on topic Technical Bulletin M4-101
Just caught the tail end of this conversation but this references transmission assembly for Motocross DT1’s if this is what your looking for...
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
‘12 Triumph Scrambler
Last edit: 14 Jan 2021 21:59 by JGersh.
14 Jan 2021 21:53 #4
