piston and rings
  • tvrc18
  • tvrc18's Avatar Topic Author
piston and rings was created by tvrc18
On the parts list for a 1968 YG5T piston and rings there are 2 listed, Keystone and I guess non Keystone. What are the differences and can you mix parts?
09 Dec 2020 15:40 #1
Replied by RT325 on topic piston and rings
For sure keystone rings won't fit a non keystone piston. Might only be the top ring thats tapered but not sure where i'm heading but thinking if you had a non key piston maybe two sets of key ring might work if you used the second ring from both. Don't read too much into that statement. Someone will sort it or sort 'me' lol.--if, in fact that is what the difference in part numbers means? Anyone?.
09 Dec 2020 16:20 #2
Replied by Swoop56 on topic piston and rings
If your current piston has a K stamped on the crown , you need Keystone rings .
That's assuming it's a Yamaha piston .
Mixing between the two types won't end well . Don't ask how I know .
09 Dec 2020 23:10 #3
Replied by MarkT on topic piston and rings
Someplace I remember seeing a list of rings showing the two types and part numbers. I will see if I can find it.
09 Dec 2020 23:28 #4
  • tvrc18
Replied by tvrc18 on topic piston and rings
Unsure of the part number for the standard rings for a keystone piston. Piston has a K stamped in it. Babbits online shows the part numbers but so many variants on different sites.
10 Dec 2020 18:50 #5
YG5T came with keystone rings standard according to a Yamaha doc I found.
Prefix = 180
Body = 11601 = both chrome plated
Body = 11610 = top ring chrome, second ring cast iron
Suffix = 00 = standard size
Suffix = 10 = first over
and so on... to 40
As far as installation, Keystone rings are stamped with letters/numbers near the end gap. Numbers go up. The ring with a "1" in the number (1N or 1T) is the top ring. The ring with the "2" in the number (2N or 2T) is second ring. Oversize, if applicable, is supposed to be stamped on the other side of the gap.
This came from a 1969 document so it's possible things changed since then. If this doesn't make sense, post up the numbers and maybe someone like Enduronut can help.
10 Dec 2020 20:39 #6
  • tvrc18
I ordered 180-11601-01 hoping they are Keystone.
10 Dec 2020 21:45 #7
  • tvrc18
Noticed the 80 cylinders from mid 60's have different part numbers first three digits 168 and 180, even pistons have the different numbers also. What do you suppose the difference is? Are they interchangeable?
11 Dec 2020 10:39 #8
My guess is yes? But I don't know for sure. Later models have different porting and something like pipe flange could be different.
Pistons might only be ring difference and/or possibly ring locating pin difference. I know that many, many years ago when I needed a piston for my 1964 MG1T as a kid, the dealer didn't have the exact part so they looked through the parts bins and found a piston kit with a different number from a later model that worked fine. Might have been a YG5 or GS6 piston that we put in a YG1 cylinder? Too long ago, just my guess. If I remember right, one of the parts guys said something about the newer model piston working in the older engine but not the other way around... which sounds like ring gap pin location to me.
11 Dec 2020 12:07 #9
