1971 DT1E Clutch Lever Hard to pull.
  • GOPOPRACING
  • GOPOPRACING's Avatar Topic Author
1971 DT1E Clutch Lever Hard to pull. was created by GOPOPRACING
1971 DT1E 250 clutch? Has anyone used lighter clutch springs, than the standard, to make the clutch easier to pull. Trying to reduce the clutch lever pull for a young lady to ride. Thought about using PN 90501-20125-00 off an AT1C. She is not going to be racing enduro or motorcross, so clutch slip should not be a big issue. Thanks for any suggestions. Using a tennis ball to strengthen he grip is not the answer I am looking for.
14 Nov 2020 09:18 #1
Replied by Gr8uncleal on topic 1971 DT1E Clutch Lever Hard to pull.
Not a direct answer to your question, but in the past I've fitted dog leg levers to some of Gr8auntiepat's bikes, so that she wasn't operating the clutch with just her fingertips.
14 Nov 2020 10:25 #2
Replied by MarkT on topic 1971 DT1E Clutch Lever Hard to pull.
I think this was mentioned on other threads I'm pretty sure you started... most of the time a difficult clutch pull is caused by a gritty or damaged worm gear and/or clutch cable.
If you haven't thoroughly and meticulously cleaned, lubed, and/or replaced the cable and worm gear that's where you need to start.
They also make an "easy pull" clutch lever assembly... GFrench has used them on his projects.
yamaha-enduros.com/index.php/forums/the-...-for-califonia#11087
yamaha-enduros.com/index.php/forums/yz-m...-400?start=110#74659
The following user(s) Liked this Post: GOPOPRACING
14 Nov 2020 12:02 #3
  • GOPOPRACING
Replied by GOPOPRACING on topic 1971 DT1E Clutch Lever Hard to pull.
Good information. Thank you,
14 Nov 2020 12:51 #4
