Choke on 1975 MX400
- Andy_911
Choke on 1975 MX400 was created by Andy_911
Any clues on how the choke stays up on my MX400? I can pull it up then it just falls back down
14 May 2023 08:54
Replied by MarkT on topic Choke on 1975 MX400
On most models there's a clip that goes into a slot just above the nut flats. Clip catches a groove in the plunger shaft.
Clip could be bad/missing/broken or groove in plunger shaft could be worn. Clip should be under boot just above nut part.
Sometimes if it's a worn groove in plunger shaft you can lift plunger and rotate shaft slightly to a fresh section of groove.
The following user(s) Liked this Post: RT325, Gr8uncleal, Ht1kid, Andy_911
14 May 2023 09:06
Here's some pics of typical parts...
Groove in choke plunger shaft:
Slot in choke nut:
Choke clip. Straight part where arrow points goes across where my arrow points on choke nut... catches groove on shaft.
Slot in choke nut:
The following user(s) Liked this Post: RT325, MACE6772, Gr8uncleal, Schu, Ht1kid
14 May 2023 09:23
- Andy_911
Replied by Andy_911 on topic Choke on 1975 MX400
Turning it works a treat. Thanks @MarkT
14 May 2023 09:24
- Lizeec
Replied by Lizeec on topic Choke on 1975 MX400
You are missing the little knob on top of the choke plunger, this is what it should look like (random eBay picture) they are kinda rare as they always break and fall off, I have removed the choke plunger and used a 4mm or 5mm dye (can’t remember which size) to cut threads into the shaft and threaded on a knob that you can get at most hobby shops.
The following user(s) Liked this Post: MACE6772, Andy_911
16 May 2023 12:18
Yamaha went to extremes on leaving off even small parts to save weight... It would not surprise me if the MX/YZ models did not come with a choke knob.
The following user(s) Liked this Post: MACE6772, Ht1kid
16 May 2023 16:02
