DT360 float bowl
- pahiker
Replied by pahiker on topic DT360 float bowl
Have you tried dunking the carb in a carb cleaning solution like Berryman chem-dip or using an ultrasonic cleaner? I physically scraped what crud I could get to with a plastic card, then used Berryman to take care of the tiny passages and jets. Ran great afterwards.
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
2024 Suzuki DR650
05 May 2025 07:53
#11
- jsmith6752
Replied by jsmith6752 on topic DT360 float bowl
thanks I will give it a shot.....
05 May 2025 08:41
#12
- Schu
Replied by Schu on topic DT360 float bowl
Just curious.
Will it start if you hold the throttle wide open when you kick it over?
05 May 2025 15:24
#13
- jsmith6752
can' tell yet the throttle cable broke but thanks
06 May 2025 07:44
#14
Replied by Gr8uncleal on topic DT360 float bowl
I assume that you have the correct carb? It should have 445 stamped on the outside, as well as a banjo bolt fitted into the float bowl, into which the main jet is screwed.
Yamaha DT360 1974 USA CARBURETOR - buy original CARBURETOR spares online
06 May 2025 09:33
#15
- jsmith6752
good info I will have to check that thanks
06 May 2025 11:23
#16
