DT360 float bowl
- jsmith6752
DT360 float bowl was created by jsmith6752
My bowl appear to be missing the jet in the corner of the bowl. Can they be had anywhere?
29 Apr 2025 20:18
Replied by Gr8uncleal on topic DT360 float bowl
According to Partzilla, these other models used the same part (click on "Product Fitment").
YAMAHA OEM BODY FLOAT CHMBR 1 - 214-14181-12-00 | Partzilla.com
- jsmith6752
Replied by jsmith6752 on topic DT360 float bowl
says it does not fit a 74 DT360
30 Apr 2025 04:43
It's just the way the site is formatted. It looks like the model you select the part from isn't shown, so view the list as "also fits".
Yamaha Motorcycle 1974 OEM Parts Diagram for CARBURETOR | Partzilla.com
30 Apr 2025 05:07
Replied by RT325 on topic DT360 float bowl
I've never ever seen one of those fixed jets escape but there's a first for everything lately on here. It would still run normaly with the choke closed, but be interesting to experiment to find out how rich starting the choke is minus that small jet.
I thought--without looking--that the pipe which extends down into there only has a small hole in the end anyway.
Unless i have my carb types muddled up.
30 Apr 2025 07:47
- Swoop56
Replied by Swoop56 on topic DT360 float bowl
Any DT1/2/3 carb bowl will do the trick , but may need painting .
Someone could have a parts carb lying about .
30 Apr 2025 14:13
Well there ya go, I'm still learning & didn't realise dt360a had the side mounted main jet. 214 part numbers I always relate to dt1. Thanks Swoop. Ps. Hope ya not flooded out down there. Looks as bad as it gets, or worse.
- automan
Replied by automan on topic DT360 float bowl
Some bowls have no starter jet.
Do you know you need it?
01 May 2025 05:05
- jsmith6752
Don't know for sure but the bike does not like to start with out starter fluid.
