turn signal wires
  • jsmith6752
  • jsmith6752's Avatar Topic Author
Replied by jsmith6752 on topic turn signal wires
what is the rectifier for?
13 Nov 2024 17:08 #11
Replied by Ht1kid on topic turn signal wires
A rectifier converts a/c voltage from your stator to d/c voltage to your battery
13 Nov 2024 17:40 #12
  • jsmith6752
so where does my my yellow wire hook to?
13 Nov 2024 18:48 #13
Replied by RT325 on topic turn signal wires
The blue runs off the mag lighting coil in a long convaluted way via the switch, so if the regulator yellow goes into the blue it controls the headlight & instruments plus tail light where i am in NZ but US models might have a DC powered tail light, not sure.
No matter the regulator will save headlight & instruments.
Just a note though, the blue is only live when the motor is running, same with headlight--& probably/maybe tail light.
Last edit: 13 Nov 2024 19:11 by RT325.
13 Nov 2024 19:08 #14
  • jsmith6752
ok thanks so I splice the yellow wire into the blue wire?
13 Nov 2024 19:26 #15
Replied by pabdt on topic turn signal wires
edit:  I see you mentioned yellow from the regulator.  my mistake.  I thought you were asking about the headlight.  I'll leave the info below for reference purposes.
The yellow headlight wire, the high beam, is powered directly by the HI/LO beam switch on the handlebars. This connector is in the headlight bucket. Note, also in the bucket is a connector to the HIGH BEAM indicator in the instrument tachometer.
The blue wire going to the HI/LO beam switch, from the on/off switch for lighting, is switched to either the yellow (high beam) or green (low beam).
I just completely rewired my 74 360, though I did use a 12V VAPE system. Stock, I had a 6V system with no regulator from Yamaha. My 74 DT125 does have a 12v regulator.
If you had a regulator in the headlight bucket, looks like some previous mods or maybe the 360 had a regulator in some locales and others not.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
Last edit: 13 Nov 2024 22:00 by pabdt.
13 Nov 2024 21:51 #16
JSMITH, try downloading and reviewing the DT400B or C wiring diagram on this site. It will clear up a few things for you and is easier to read than the 360 wiring diagram. Its almost identical.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
13 Nov 2024 22:14 #17
  • jsmith6752
Thanks, I think I understand now. I am printing this out and taking it out to my shop.
14 Nov 2024 05:05 #18
