One out, one in
- Steve F
Replied by Steve F on topic One out, one in
Schu, could you use an 'o'ring backer on the screw to help with that issue?
1974 DT250A
1974 DT250A
1977 IT175D "Alex"
1978 IT175E
1972 DT2 "Adam"
1973 DT3
"And there ya have it"
1974 DT250A
1977 IT175D "Alex"
1978 IT175E
1972 DT2 "Adam"
1973 DT3
11 Jan 2025 14:59
#21
- Schu
Replied by Schu on topic One out, one in
Yes that probably would have kept it from happening.....
The air pocket is irreversible at this point.
Live and Learn
The following user(s) Liked this Post: Steve F
- pabdt
Replied by pabdt on topic One out, one in
great work sir. Nothing better than a restored part that turns out excellent.
note to self: send exhaust and badges to Pete for resto...
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
- Pete-RT1
Replied by Pete-RT1 on topic One out, one in
Fab time in the fab shop yesterday, I had a go at mig welding and it might not be pretty, it's certainly solid.
Tricky to get the curve pieces correct, had to slot the flat part of the angle to allow for the bend and there's a dip where the seat latch is.
Probably easier to have made the angle in two pieces and weld at the angle, but I didn't do it that way.
Bit of cleaning up of the underside welds to do, will leave foam side alone to keep the strength.
I'll tack on the barbed strip next week.
This seat is the '71 seat that came with the bike, my AT1-C currently has a '69/'70 seat on, so this one will eventually go on that bike and with the seat I bought with the bike I'll end up with a spare.
Finished off the exhaust, tidying up the fake seam tacks and giving it several coats of PJ1.
I found correct main jet and a pilot jet without a damaged slot in one of my parts boxes, so I can finish the carb.
I'd like to get the bike running before I tear it down, just to see what it's like.
Moving forward, but plenty left to do.
https://
https://
https://
https://
https://
https://
Yamaha CT3 (in bits)
The following user(s) Liked this Post: MarkT, Steve F, Swoop56, pabdt, Schu, Ht1kid, Sneezles61, Tinkicker, Badrul
19 Jan 2025 06:18
#24
Replied by Ht1kid on topic One out, one in
Great job Pete
20 Jan 2025 07:49
#25
- Pete-RT1
We've got a runner!!!
Borrowed the tank from The Doppelganger and put the freshly cleaned carb back on.
Kickstart, decided to stop engaging after a few kicks, but my battery drill on the mag nut soon got things going.
Sounds good, apologies for the short video.
1969 CT1 Initial Start-up
The following user(s) Liked this Post: MarkT, RT325, pabdt, Schu, Ht1kid, Tinkicker
Replied by RT325 on topic One out, one in
Love watching the progress thanks.
I used to attempt things like you're doing when i had an ocy acetylene set but got too expensive to have sitting mostly doing nothing. Have an arc welder but that's only good for blowing holes in thin stuff. I need a tig welder.
20 Jan 2025 15:09
#27
- Pete-RT1
Few more bits done.
Fabrication work on the seats is done so I have just this minute, painted the foam side with Hammerite Smooth, the other side will be spray painted once I get chance.
The rusted end of the exhaust silencer has now been replaced.
I bought a vice for pillar drill a few weeks back, specifically for the job of holding the tube whilst drilling the holes, unfortunately I've put it somewhere so safe that I can't find it.
Had to improvise with a piece of decking board and some batton to hold the tube while I drilled it, I still haven't found the vice
I'm enjoying learning to weld, I'm sure a lot of you already have that skill.
Air filter that came with the bike was a paper one that had seen better days.
'69 model would have originally had a foam filter and cage, so I used the expired paper one and some perforated steel sheet to make the early version.
Foam yet to be fitted.
https://
https://
https://
https://
https://
https://
https://
https://
https://
https://
https://
https://
The following user(s) Liked this Post: MarkT, Swoop56, pabdt, Schu, Ht1kid, Sneezles61
02 Feb 2025 09:31
#28
- Pete-RT1
Seat complete, less the fittings.
I bought a second set of gauges from the US for a fair price and looks like it was a good idea.
I dismantled and lubricated the originals but the drive shaft for the odometers is worn and the odometers don't work because of it, so both sets ended up getting some love, will get some nail varnish to seal screws etc.
https://
https://
https://
https://
https://
https://
https://
https://
The following user(s) Liked this Post: MarkT, swm, pabdt, Schu, Ht1kid, Sneezles61
21 Feb 2025 05:44
#29
- Pete-RT1
Finally pulled the trigger and completed the strip-down today before the heavens opened.
Bike now fits in the shed easily
Orders placed with KDI and Deet, special thanks to Deet for consolidating the orders to keep shipping costs down.
https://
https://
The following user(s) Liked this Post: MarkT, RT360Fan, RT325, Sneezles61, pahiker
23 Feb 2025 12:25
#30
