1974 DT360 Disassembly and Restoration
  • pabdt
  • pabdt's Avatar Topic Author
  • Online
  • Platinum Member
  • Platinum Member
Replied by pabdt on topic 1974 DT360 Disassembly and Restoration
These were :
1. Alum Oxide blasted. Clamps removed and polished.
2. File to remove sharp spots
3. Using high speed dremel barrel tool with fine grit, ground vertically. It the easiest way to sweep the face smoothly.
4. 6" rough alum oxide wheel
5. Will bake 30 min to remove oil
6. bake another ~10 w/powder coat.
Trying different techniques to cleaning these. The ones on the far left and right were very pitted to start with. Two of them will be gloss black powder coat and one of them cleared. Will post the after pics when done.
Close-up of one on far right. More work to do here, but interesting results.
Front:
Back:
Final Product:
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
Last edit: 26 Oct 2020 15:42 by pabdt.
25 Oct 2020 17:57 #131
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
Starting to look at the engine. Do plan a complete disassembly and inspection. Still working on other things, but looking at piston and cylinder tonight. They don't look bad. Guess I should go first over?
Anyone have dimensions on pistons/cylinders, etc? service manual n/a at this time online.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
02 Nov 2020 20:14 #132
Replied by MarkT on topic 1974 DT360 Disassembly and Restoration
Our fearless leader is working on the "page 2" of the Service Manuals not working...
In the meantime, try this link as a workaround.
yamaha-enduros.com/index.php/workshop/service-manuals?start=21
02 Nov 2020 20:51 #133
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
:likey
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Last edit: 02 Nov 2020 21:48 by pabdt.
02 Nov 2020 21:48 #134
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
Just a quick look, but looks like a stock piston about 80mm.
I found a 1st over OEM piston and rings!
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
02 Nov 2020 21:57 #135
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
few pics of the rear fender before and after.  as soon as my DC Plastics front fender arrives, I can pop a top on the 2k clear and get them both finished.
looks like some filler in some of the holes...
beginning of metal work/body filler.
waiting for paint...
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Last edit: 30 Mar 2021 20:52 by pabdt.
30 Mar 2021 20:47 #136
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
Fuel tank not as bad as it looks. the inside is actually very clean.
looks like the letters were crooked from the factory.   need to make a template to get this right on application of the new decals.
Top left qtr near seat test painted using MDScott's same paint; Sierra Pine.  Note, the paint within the Yamaha circle on left side was not painted.  Paint
looks pretty much dead on less oxidation,etc.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Last edit: 31 Mar 2021 14:39 by pabdt.
30 Mar 2021 22:29 #137
Replied by msavitt on topic 1974 DT360 Disassembly and Restoration
piston and cylinder look decent
Does bottom end, wrist pin/brg seem tight?
what's the ring gap?
if it is in spec (not likely) or just slighly over, then you could probably give it a hone and get the gap into spec with stock rings.
I had to go OS with my Xmas meltdown to clean up some scratches and ended up spending a almost 200 euros at CMSNL
ps. i have a matching gas tank, same dents!
31 Mar 2021 07:43 #138
ps. I would definitely change the crank seals, making sure to use the ones with the two garter springs, not the transmission seals that I unknowlingly was sold by a certain scavenging bird on ebay before learning more about proper seals and pressure testing on this site
31 Mar 2021 07:45 #139
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
going to restore the engine, bearings, seals, all.  transmission seals?   ok, who was that?
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
31 Mar 2021 18:34 #140
