Blaster 200 crank
- Robdangereux
Blaster 200 crank was created by Robdangereux
Simple question will the blaster 200 crank fit into my 1978 dt175 crankcases and fit my flywheel etc? Cheers Rob
15 Feb 2025 16:41
Replied by MarkT on topic Blaster 200 crank
Simple answer - NO
You can probably install a complete blaster engine though.
15 Feb 2025 18:36
- Robdangereux
Replied by Robdangereux on topic Blaster 200 crank
Shame, in England finding a blaster engine is not easy. And there doesn't appear to be big bore kits for the 175. Thanks for your input.
16 Feb 2025 01:01
A stock blaster has about the same HP as your DT175.
A good port job from someone that knows what they are doing can make a huge difference... I built a mildly modified 175 that exceeded 90 mph (GPS verified) on a dry lake bed. Front wheel comes up under acceleration if you're not careful. And there are many shops that know a hell of a lot more about modifying porting than I do. (I also used a 77-79 IT175 cylinder head with centered combustion chamber and smaller volume to make up for lost compression after raising the exhaust port)
Stock exhaust can also be replaced with aftermarket... someday maybe I'll get a "Big One" pipe from the UK if they are still available.
16 Feb 2025 02:09
