GFrench- TWO 1971 JT1Resorations
- pabdt
Replied by pabdt on topic GFrench- TWO 1971 JT1Resorations
What are your comments on the "EXTREME" BLACK CHASSIS GLOSS VS BLACK CHASSIS GLOSS?
I have read the extreme is some tough paint. I used it on my seat pan as a test. I thought it came out ok.
I have not, but plan to spray the frame next.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
23 Mar 2026 17:42
#11
- GFrench
- Supporting Moderator
Replied by GFrench on topic GFrench- TWO 1971 JT1Resorations
Good that you have tried the "Extreme" flavor- I have not
This is what Eastwood details with the Extreme-
"3 times more resins make it 3X more durable than our original Chassis Black coating. This maximum-durability, 85%-gloss auto chassis paint formula offers improved resistance to brake fluid, fuel, solvent, chips and scratches".
Sounds like it would be almost bullet proof and would be a good choice... I just know the regular Chassis Paint in Black that I used on mine provided Excellent results and the finish looks as good as one of Power Coated frame... so I am good with that.
Per Eastwood- Original Chassis Black Gloss is the perfect coating at the perfect price for any under car component.
- Resists corrosion, chips and scratches
- Resists brake fluid, fuel, solvents, UV
- Matches OEM finish
- Apply multiple coats without lifting
- 85% + Gloss Level
1971 DT1F MX 250
1973 RT3 360 "Black Widow"
1973 RT3 360
1976 IT 400 / redesigned as a 75 MX400
1971 DT1F MX 250
1973 RT3 360
- pabdt
Ooops. Sorry, I saw you posted a picture of the extreme in another thread. lmao why I got that one.
No matter, its fun experimenting. thanks for the info.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
24 Mar 2026 00:03
#13
- GFrench
Dang.... Your right!
I did not even realize I had bought / used the Extreme on the 71 DT1MX bike... was not even aware there were two different ones until you mentioned it as I was just focused on the "chassis Paint" detail.
SO.... The Extreme did work very well... I will use the regular Chassis paint on the Mini Enduro's since these bikes will not be daily riders of any sort- to see how it works and if it comes out as good.
With this new discovery- I would go with the Extreme on any rider bike for sure... Thanks pabdt
1971 DT1F MX 250
1973 RT3 360
1971 DT1F MX 250
1973 RT3 360
- Schu
Replied by Schu on topic GFrench- TWO 1971 JT1Resorations
“Tank Stripe... have never done this before and it can be a slight challenge to get the exact line... to many time see folks go to all the time and expense to paint and then there is the stripe staring at you that just kills it! It has to be perfect”
Oh man ain’t that the truth….. I did OK on the left side and blew it on the right side. It bugs me every time I look at the right side.
imgur.com/a/ZqPd7uI
imgur.com/a/ZqPd7uI
The following user(s) Liked this Post: GFrench, MarkT, pabdt
24 Mar 2026 11:00
#15
- GFrench
Finding a little time here and there to make continued progress on the Two JT1 Mini's!
My first goal is to attack the Tins- to get them to a final stage ready for Primer- Base Coat and Clear Coat. I found a line of Paints (new to me) and from what I read are really DYI user friendly in Aresol Cans producing high quality results... More on the line of Paint that I will be using soon.
So- first was to start with the Gas Tanks... One of the tanks was not in bad shape other then a few dings and some areas of pressed in.... The other tank suffered some damage in it life... but I have sure seen worse- Both will fix up nicely.
I bought this Dent Puller Kit off Amazon- I was suspect that this thing would actually work but to my surprise it does a pretty amazing Job in pulling a large dent out to a much smaller where body filler can easily finish it off.
It comes with a Hot Glue Gun and many long glue sticks- along with many different tabs you can attach / use depending on size and depth of dent... Just Hot Glue on in place... Let it set to allow the Glue to completely harden...
Then hook this tool or you can also use the Slide Hammer that comes with the kit... and slowly just keep applying presure and you will see the tank flexing in the dented area.
After:
So to start this whole process... I went ahead and Stripped all the paint off the tanks and Fender to get them down to bare metal and then marked up the bad spots to start the first layer of filler... 80 grit scratch marks in the damaged areas so the filler will adhere.
Time to mark up the dents and prep Filler
First layer applied- Now TON's of sanding!
After:
1971 DT1F MX 250
1973 RT3 360
1971 DT1F MX 250
1973 RT3 360
The following user(s) Liked this Post: MarkT, swm, pabdt, Ht1kid, pahiker, Tinker man
- GFrench
Body filler / work is now done and everything is prepped for next step- High Build Primer
So today got everything wiped down and got the High Build Primer sprayed on---
I am using the Alpha Paints on this project. Heard many good things about their products and to have Aerosol Cans for everything makes it super easy!
I will be using their High Build Primer- 1K Epoxy Primer Sealer- Base Coat Colors and their 2k Gloss Clear Coat- Looks to be a solid program and the Spray cans are outstanding... just like a spray gun.
All set now with High Build Primer- will do the final blocking / sanding using a guide coat to make sure there are no remaining low spots-
Then I will be ready for the 2nd step to apply the 1k Epoxy Primer Sealer product to lock everything down and leave a perfect surface for the Base Colors- Found the Perfect Red and White paints to match the OEM color.
1971 DT1F MX 250
1973 RT3 360
1971 DT1F MX 250
1973 RT3 360
The following user(s) Liked this Post: swm, Swoop56, pabdt, Schu, Ht1kid, pahiker
03 Apr 2026 20:12
#17
- Pete-RT1
Replied by Pete-RT1 on topic GFrench- TWO 1971 JT1Resorations
" thought I would take some time to practice laying down the Tank Stripe... have never done this before and it can be a slight challenge to get the exact line... to many time see folks go to all the time and expense to paint and then there is the stripe staring at you that just kills it! It has to be perfect"
Greg I'm the same when it comes to the pinstripe.
I've never done a JT1, but I've done a few others, is it 5.5mm wide like the other models?
In my view the curve coming over the top meets the horizontal on the seat end of the tank creating a 90 degree angle.
At the seat end if you struck a vertical line from the inside of where the points meet, the curve never goes past that point and the angle is always decreasing.
Here's a photo from the JT1 brochure for reference.
Good luck with it.
https://
Good luck with it.
https://
Yamaha CT3 (in bits)
The following user(s) Liked this Post: GFrench, Snglsmkr
05 Apr 2026 13:41
#18
- GFrench
Been away for a bit... have a lot of Spring Projects going on around our place here in Texas...
Been making good progress on the two 1971 JT1's in getting all the Tins Prepped lots of hours of pulling dents applying filler and more and more sanding... seems like it will never end but as we all know it is in the preparation to achieve the best results!
I am very pleased with the finished product using the TSS Alpha Aerosol Cans they have very good quality Primers Base Coats and 2K Clear.
Here is a photo dump of the process...
After a lot of laying out and taping off all the lines was time for Base Coat White then overlay with the Red lastly 4 coats of the Alpha 2k Clear Coat- this stuff is Amazing!
Now will finish the tear down of both bikes for next step to Clean and Restore the Original Parts and get the Frames Prepped and Painted.
1971 DT1F MX 250
1973 RT3 360
1971 DT1F MX 250
1973 RT3 360
The following user(s) Liked this Post: Rick C., swm, pabdt, Schu, Ht1kid, Tinker man
- Rick C.
Replied by Rick C. on topic GFrench- TWO 1971 JT1Resorations
Stellar job Greg.
Scott tells me that you and Gary are talking about something on Facebook.
Any chance Youse guys might post up here on the forum for those of us that don't Facebook?
From what I gather ... we are getting the Band back together??
22 Jul 2026 15:09
#20
