Carburetor won't fit on Yamaha GT80 (Help)
  • flaps8
  • flaps8's Avatar Topic Author
Hello, guys! I'm new to this forum, but it seems really friendly. I just got Yamaha GT80 that won't start (they said piston was melted), and I have plans to restore it. So when I got it, some of the parts were apart, including carburetor. I just checked it for spark and it's good, but I got the other problem. The carburetor that came with that bike won't go into reed valve port. I thought maybe I'm doing something wrong, or its not the right carburetor. Anyways I'm in desperate help! Do you know what it could be?
Pictures: imgur.com/a/XipUxXZ
Last edit: 29 Aug 2024 15:14 by flaps8.
29 Aug 2024 15:12 #1
Replied by RT325 on topic Carburetor won't fit on Yamaha GT80 (Help)
Welcome from NZ. Carb doesn't look GT80 sorry. This is the right type of carb in the random video i just found. Best of luck finding one. I'll go looking at cheapy chinese & see what shows up. I know people rubbish them but i use them. Cheers.
The following user(s) Liked this Post: flaps8
29 Aug 2024 17:21 #2
Here's a good start if it'll fit & probably jetted close enough to get ya going. Not very expensive if it doen't work out.
Cable operated choke but i'm sure you could devise a way like pull it with some wire or get an ols bit of throttle cale with the small nipple to hook into the choke slide. It'll start without choke in the mean time just hand over the carb mouth for a kick or two.
Looking again & just to confuse they give two optiond of alloy haha.
Bit hard to see on my computer but looks like the insultor mount part says 15mm ID.
www.aliexpress.com/item/1005007472146590...arch%7Cquery_from%3A
Last edit: 29 Aug 2024 18:11 by RT325.
29 Aug 2024 17:39 #3
This cable would sort the choke.
I see there's diferent options so probably the second across with the least sticking out 51mm & small nipple.Anyway--your choice & don't let me sway you away from genuine that others will recommend.
After all that i'm not now sure about second one looking at the fitting on the outer cable compared to the first one but 70mm free cable on first one sounds a lot so might go through an adjuster or probably a bent plastic elbow too to need more cable. Sorry, i'm mucking you around.
www.aliexpress.com/item/1005007095062883...arch%7Cquery_from%3A
Last edit: 29 Aug 2024 17:56 by RT325.
29 Aug 2024 17:46 #4
  • flaps8
Replied by flaps8 on topic Carburetor won't fit on Yamaha GT80 (Help)
Thank you, man. I will try to sand the inner side of carburetor port, so it would fit, but if it doesn't work, I'll look for Chinese carbs
29 Aug 2024 18:33 #5
Replied by MarkT on topic Carburetor won't fit on Yamaha GT80 (Help)
What's the outside diameter of the manifold spigot? I have a few Mikuni spigot mount carbs and might have one that fits.
Treatland in California has a lot of those type carbs and is having a 13% off sale this weekend.
29 Aug 2024 18:42 #6
  • flaps8
It's 20mm. But I'm located in Canada, so I think it wouldn't work
29 Aug 2024 18:52 #7
No mail or packages allowed into Canada?
29 Aug 2024 19:10 #8
  • flaps8
You're right. I will try sanded carb, and if it doesn't work I might buy one from you. How much do you want?
29 Aug 2024 19:39 #9
Let me look tomorrow and see if I have a 20mm one.  Cheap, like $20 + shipping.
The following user(s) Liked this Post: Wrench66
29 Aug 2024 20:02 #10
Moderators: yamadmin, Makotosun, DEET, Vinnie, Mini Enduro Man, James Hart
