No dipstick just a plug!
- principal282
No dipstick just a plug! was created by principal282
Been a bit of oil under my little red 74 gt80. Today I replaced the oil line , and seems a lot less. But there has been trans oil too when warm and I pull in. I go to check and there is no dipstick!! Just a plug? Am I missing something?
24 Aug 2024 21:09
Replied by MarkT on topic No dipstick just a plug!
The 80's had a separate dipstick in the tool kit.
The following user(s) Liked this Post: Badrul
24 Aug 2024 21:31
The following user(s) Liked this Post: principal282, Tinkicker
24 Aug 2024 21:37
- Tinkicker
Replied by Tinkicker on topic No dipstick just a plug!
Was that an attempt to overcome the "Should the plug be screwed in or out to dip" confusion?
25 Aug 2024 04:47
- principal282
Replied by principal282 on topic No dipstick just a plug!
Thanks, Mark! As always, you knew!! ordered!
my goal is no more oil dribbles on garage floor.
I had a brittle oil line dribbling a bit, but I also wonder if I might have a bit of trans oil leaking somewhere too.
seemed down a bit so I want to keep a close eye on it.
good luck with the inventory reduction. Hope you can still enjoy some of your road worthy collection.
25 Aug 2024 05:44
- Schu
Replied by Schu on topic No dipstick just a plug!
Once you receive your dipstick, would you be so kind as to share the measurement on the actual length of the dipstick from end to first bend of the handle?
I ended up making my own based on filling it up with the proper amount of oil and then trimming a coat hanger wire down as needed and bending the handle. But I would like to know how my homemade dipstick matches up to a Yamaha dipstick.
25 Aug 2024 06:10
- principal282
Yes sir Schu will be happy to do. Should be here next weekend. I live in the remote bush (well, almost) but in nodak were a long way from everywhere!
25 Aug 2024 06:38
Tinkicker wrote: "Was that an attempt to overcome the "Should the plug be screwed in or out to dip" confusion? "
I don't think so... many of the smaller engines had this "feature"... The early YG1 (80) and the 1988-90 DT50 (17W series we got in the USA) did as well. It looks to me like the problem is the clutch or a gear gets in the way of having a dipstick in the center of the fill plug.
25 Aug 2024 08:30
- Schu
Did you receive your dip stick?
I'm anxious to confirm the proper length on my homemade version.
10 Sep 2024 18:00
- principal282
Schu, mine is here. 80mm to end of stick. 75mm to top of the safe zone.
11 Sep 2024 20:23
