74 gt80 slipping kick starter
  • principal282
  • principal282's Avatar Topic Author
74 gt80 slipping kick starter was created by principal282
Aghhhh tonight after my points were set, I checked for spark.  My kick starter seems to slip, like it kicks part way and then slips.  I hope it’s a simple fix. Any ideas what it may be?
I found a switch, good, used , will clean it up and possibly sell the guts of old one.
Points set using deets write up.a little trickysetti g up the magnet in limited space but we made it.  It’s now dead on.
16 Oct 2023 21:39 #1
Replied by RT325 on topic 74 gt80 slipping kick starter
First off, it'd be good if its just the lever loose & jumped a few splines although still annoying to fix.
But after that, read below which i wrote first.
I'm guessing it 'is' actually engaging, which is the gear moving out the twisted spline, but if #14 circlip had popped off out of the circlip groove the gear could move out further than desired & tension clip might escape past the end of its guiding slot.
Best to pull the cover & check it all.
Also be sure the tension clip #17 is in its guiding slot or won't tension the gear to move out the twisted spline & engage.
Check the intermediate gear the kick gear engages with & feel it for up & down to get a feel of the case bearing behind it. Actually might just run in a brass bush, i'm not sure.
Then also check the small gear behind the clutch which is the final gear to get things spinning.
Unfortunately the clutch might have to come off to get a look at the small gear.
www.partzilla.com/catalog/yamaha/motorcy...4/gt80a/kick-starter
Here's the clutch with small gear on the back of it.
www.partzilla.com/catalog/yamaha/motorcycle/1974/gt80a/clutch
In link below #22 is the intermediate gear the kick gear moves over into from beside it.
www.partzilla.com/catalog/yamaha/motorcy...4/gt80a/transmission
Last edit: 17 Oct 2023 01:19 by RT325.
17 Oct 2023 01:04 #2
  • principal282
Replied by principal282 on topic 74 gt80 slipping kick starter
I think my kick lever splines are shot
See pic
photos.app.goo.gl/bvckVh55RUjL4bMn8
17 Oct 2023 14:59 #3
Replied by Ht1kid on topic 74 gt80 slipping kick starter
Yes it’s shot how does the shaft look? Probably the same
17 Oct 2023 15:34 #4
  • principal282
Much much better imo
photos.app.goo.gl/nifEe42ThM3sh3gMA
oem is hard to come by
aftermarket is usually crap
any crossover with Honda/Suzuki/Kawasaki?
About 135mm center of shaft to pedal
12.2 mm at the spline
17 Oct 2023 17:00 #5
Looks like a a YZ or DT 80 will fit according to partzilla yes your shaft looks great
Last edit: 17 Oct 2023 18:19 by Ht1kid.
17 Oct 2023 18:18 #6
  • principal282
Thanks! Found one for a gt1 on eBay.
17 Oct 2023 18:20 #7
Moderators: yamadmin, Makotosun, DEET, Vinnie, Mini Enduro Man, James Hart
