Testing your ignition in a No Spark Condition
- Makotosun
- Administrator
Testing your ignition in a No Spark Condition was created by Makotosun
This post is reposted from the
Hodaka Club Forum
. I found it to be a very useful troubleshooting system, and the points ignitions on the Hodaka's are almost identical to the ones used on the Yamaha bikes. Originally written by my friend Dale Dvorak.
When you encounter a "no spark" condition, how can you go about isolating the problem? Well, here is what I do.
First, disconnect the main key switch (if applicable). The key switch, in the off position, grounds the ignition (black lead at the ignition coil). A defective switch can ground out this lead.
Next disconnect the kill switch (if applicable).
Still no spark? My next move is to test for spark using an external power source. Specifically 2 D cell batteries connected in series to provide 3 vdc. A little solder, jumper wire and an alligator clip (and of course Duct Tape). Here is a picture:
This test will confirm everything except the points and possibly an open exciting coil.
Step 1: Leave the main key switch and kill switch disconnected.
Step 2: Remove the spark plug and lay it on the cylinder while still connected to the coil. Make sure that the plug is grounded to the cylinder. Use a wire jumper if necessary.
Step 3: Insulate the points. Use a strip of paper or business card.
Step 4: Connect the negative lead of your 3vdc supply to the stator (ground).
Step 5: Tap or scratch the positive lead of your 3vdc supply at the points wire connection. Each tap will provide a spark at the spark plug.
If you are getting spark by tapping at the points wire, then connect your switches one at a time. Turn the key to the on position and re-test for spark. If spark is still good, then you have a bad set of points OR your exciting coil is open. It is the exciting coil that the 3vdc supply is mimicking. Note that a grounded exciting coil would keep test spark from happening.
If you do not get a spark from your points wire then move your tapping to the condenser. If nothing, then disconnect your terminal plug going to the ignition coil and tap the connection going to the ignition coil (black wire). If still nothing then move your power supply test leads (both positive and negative) clear up to the ignition coil itself.
Note that the only thing necessary to create spark is your ignition coil and spark plug (including the plug wire and cap) If you can not generate a spark by tapping black lead at the coil itself, then the problem is either the ignition coil, the plug wire, the plug cap or the spark plug itself.
If you find that you can generate spark at the coil but not with the stator connected, then standard isolation trouble-shooting applies.
I hope that this information is found useful. You can verify an ignition coil on the bench with just the coil, spark plug and the 3vdc battery pack. Use test leads to tie your spark plug ground to your coil ground and the negative lead of your power source. Pretty simple and effective!
The following user(s) Liked this Post: MarkT, 1971DT250, DVM, RT325, Badger52, KennyV, AirborneSilva, liferbiker, Mighunter210, Patroll330
08 Jun 2019 17:40
Replied by RT325 on topic Testing your ignition in a No Spark Condition
Good to read that & thought better like it. Nearly ended up as an unlike as see i already liked it haha--in 2019, can't rememer 2019!!. Thanks for posting, or re-posting.
13 Oct 2022 23:20
- Mighunter210
Replied by Mighunter210 on topic Testing your ignition in a No Spark Condition
Thanks! This should be a sticky, very helpful. Just got spark back on my friend's DT250A. This and an analog multimeter will solve just about any ignition problem on these bikes.
13 Dec 2024 13:24
