74 DT360
  • dart451
  • dart451's Avatar Topic Author
Replied by dart451 on topic 74 DT360
Well, I took off the new Mikuni carb and replaced it with the original carb that I rebuilt a couple months ago. I kicked it till I was blue in the face! Nothing! Then I took out the outside spark plug and tested the spark, sparks beautifully! I then moved the spark plug wire to the outside spark plug and walla, it started right away! It ran for about 2-3 minutes very nicely so I backed it out of the garage to take a ride. I didn't give it enough throttle in first and it died. Never could get it started again! So, it's like the bike is moody! I don't understand how it can quit, and never pop again after running for a few minutes...
03 Mar 2026 15:40 #11
Replied by MarkT on topic 74 DT360
Bad spark plugs?
03 Mar 2026 16:30 #12
  • dart451
I test them, they spark beautifully! That's what's driving me nuts!
03 Mar 2026 16:57 #13
Not uncommon for spark to fail under cylinder pressure
03 Mar 2026 17:40 #14
Replied by pabdt on topic 74 DT360
just a thought:
If the VENT CAP is full of rust, what does the fuel exit valve look like and the exit inside the tank? much of what you have said, (dry as a bone, dies after starting, had to put choke on to run, etc) may be a lack of fuel supply.
This came from my DT125. I left it in Vinegar for several days, then washed it out with a pressure washer. Had tons of trash.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
Last edit: 03 Mar 2026 21:41 by pabdt.
03 Mar 2026 21:41 #15
  • dart451
I did clean the tank months ago and replaced the petcock so the fuel coming out, (clear tubing) is very clean and also going through a filter...thank you for your response! I think I'm going to try a new spark plug, that's one thing I have yet to try...
The following user(s) Liked this Post: Snglsmkr, pabdt, Ht1kid
04 Mar 2026 07:58 #16
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic 74 DT360
Make sure that you buy from a trusted source - lots of fakes out there in internet land.
I think that some folks here recommend Autolite (?) plugs.
The following user(s) Liked this Post: MarkT, Snglsmkr, Ht1kid, pahiker
04 Mar 2026 09:03 #17
  • dart451
Well, I tried two new plugs, one a NGK and one a Autolite, bike still will not fire. It only starts when it wants to. If you do get it started, it runs fine but don't kill it! It won't start again...
05 Mar 2026 16:07 #18
Replied by automan on topic 74 DT360
Bad SP wire to coil. Obvious.
06 Mar 2026 07:55 #19
  • dart451
That's possible, but when I take off the wire, pull the plug it fires perfectly...maybe it doesn't like it's present position when it's plugged in...I'll check that out. Thank you for the response!
06 Mar 2026 08:30 #20
