Setting Up DT-1B Carb
- Traderyoda
- Topic Author
Setting Up DT-1B Carb was created by Traderyoda
Greetings all,
I've restored a 1969 piston port DT-1B JDM motor and need some carb advice. The engine didn't come with a carb but I found a VM26 311 E2 from a later reed valve engine. I'm guessing that the jetting and settings might be slightly different for this later carb. Is there anyone running an early model engine that runs well that can guide me on how to set up my carb so I'm in the ball park? Mine is an MX machine that is set-up with autolube.
Appreciate the help and advice!
07 Jan 2024 06:15
- Traderyoda
- Topic Author
Replied by Traderyoda on topic Setting Up DT-1B Carb
I should have mentioned my baseline setup. I have a 160 main jet, a 35 pilot jet, and the needle on the 3rd notch.
07 Jan 2024 06:39
- Knutco11
Replied by Knutco11 on topic Setting Up DT-1B Carb
A service manual there should be, available for you! On this website!
www.yamaha-enduros.com/index.php/service...ctory-service-manual
Pay close attention to the air bleed. I see it calls for a .5 air jet. 35 pilot, 150 main. They also show the gyt vm30 in that manual, looks like a good one to have on hand!
- Traderyoda
- Topic Author
Yep - I have the manual. Just wondering if there are tweaks and recommendations based on experience that deviate from the manual.
07 Jan 2024 08:35
- asco
Replied by asco on topic Setting Up DT-1B Carb
160 main is very lean
180 full gasoline in the tank
200 pre mix 32/1 in the tank
three notches down is fine
1.5 turns out is good
35 pilot should be okay
air filter and exhaust questions unanswered
asco
asco
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
07 Jan 2024 08:40
- Traderyoda
- Topic Author
Will do. It's a standard enduro motor - not GYT-ed, so I stuck with the VM26.
I had the carb vapor blasted and worried about all those tiny air passage. I'll give them another look-see and make sure the air jet is the right size and is clean.
07 Jan 2024 08:47
- asco
Any DT1 250 that rolls through the doors with a 160 main jet automatically get a new 170 installed regardless of circumstance. The newer prefix carburetor shouldn’t make a difference. I don’t vapor blast carburetors. It can change things that we don’t understand?
asco
asco
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
- Knutco11
The early dt1's specify a 5d1 jet needle on the 3rd clip, an o-2 needle jet, 2.5 slide cutaway. And it shows a .5 air jet. Having seen a dt3 carburetor I am sure the air jet was open on that one. You'll want to check that, devil is in the details. Sorry I just looked again at main jets, 160 after the first year. This is just from the service manual, I'd run the 170 main as recommended.
07 Jan 2024 09:19
Replied by Ht1kid on topic Setting Up DT-1B Carb
I vapor blast all my carburetors, and then use my ultrasonic cleaner with water and a drop of dawn, and then blow out all the passageways has always worked great for me plus I have a new looking carb
07 Jan 2024 09:37
- Knutco11
Love the sonic cleaners! LA awesome cleaner as solution, brush and rinse with water afterwards, and blow dry with compressed air.
07 Jan 2024 09:42
