1973 at3 piston set
- Papawhellie
1973 at3 piston set was created by Papawhellie
I need a 56 mm piston and rings for an at3. I have some 248 pistons but no 316.
14 Oct 2022 17:28
Replied by MarkT on topic 1973 at3 piston set
Standard bore?
14 Oct 2022 17:38
- Papawhellie
Replied by Papawhellie on topic 1973 at3 piston set
Yes mark. I have a 318 mx piston without ring but I'd rather go back oem. I guess if the consensus says the mx is just as good I could just use a ring.i have 6 or 8 piston port 248 pistons I picked up at Barber. PO said the piston was stuck. He got it out and a little emory cloth or steel wool would polish it up. Its a really nice original bike so I'm ok with buying one. What type of hone do I need to get to hit the bore?
14 Oct 2022 18:28
I might have one but most of my new pistons are earlier piston port type. I will look tomorrow.
14 Oct 2022 19:11
- Papawhellie
14 Oct 2022 19:15
Only standard 125 piston I found was for an AT1.
15 Oct 2022 19:31
- Swoop56
Replied by Swoop56 on topic 1973 at3 piston set
316 piston on ebay # 193391373557
316-11610-00 rings not so many , but one set available ex ebay canada
16 Oct 2022 12:30
- Papawhellie
I saw those rings. 50+ with shipping, 30+ us. I’ll wait it out some. Bought a piston out of AL reasonable. Thanks Mark for looking.
16 Oct 2022 18:02
- Papawhellie
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=161868794914&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by RT325 on topic 1973 at3 piston set
Be careful if you go piston port CT1-175 onto a reed AT3-125 bottom end as might be a conrod length difference between reed & non reed. Like for like would be ok--like a CT3 top end.
Ok cancel that incorrect info of mine as partzilla says everything's the same.
www.partzilla.com/product/yamaha/3R2-116...7a7f00da966aa3f42951
