Replacement bulbs, speed&tach
Replied by MarkT on topic Replacement bulbs, speed&tach
P.S. The turn signal indicator is the only bulb that can't be polarity sensitive... polarity changes on the wires as you switch from right to left.
31 Jul 2021 07:11
#21
- KennyV
Replied by KennyV on topic Replacement bulbs, speed&tach
Ok so the moral of the story is if you want to switch to the LED bulbs, buy the bulbs that are not polarity sensative. I just looked at the Superbright Web site and the B9 base bulbs like I have are not polarity sensative. Wow that makes it easy. Now I'm going to order an amber for my 250A and a set for my RT2 tach, speedo and tail light.
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
21 CRF300l Rally
31 Jul 2021 07:44
#22
- Sneezles61
Replied by Sneezles61 on topic Replacement bulbs, speed&tach
I went to extract my bulbs out of the Speedo & Tach... that rubber grommet/gizmo fell apart... Dag Nabbit... I only looked at Partzilla and they don't carry them... I may just use silicone to secure them in place... It seems you can easily remove it should I have to replace bulbs... I hope..
Sneezles61
Sneezles61
31 Jul 2021 10:54
#23
- Capt.Dave
Replied by Capt.Dave on topic Replacement bulbs, speed&tach
Use eiko A62 6v 3w bulbs for your instruments. Stanley 1129 single filament for your turn signals. I think the 6 v tail light is a 1154. These are avaliable at your auto parts store.
31 Jul 2021 11:55
#24
- KennyV
Can you use a short piece of rubber hose, something with an ID that fits close to the bulb socket and an OD fits close to the tach / speedo. Slip piece of hose over bulb socket, insert bulb and slip into tach / speedo. Once tach and speedo are on the bracket, shouldn't be able to come out. And using the LED bulbs you may never need to remove them.
71 Z50 Minitrail
21 CRF300l Rally
21 CRF300l Rally
31 Jul 2021 13:39
#25
- KennyV
Oops sorry, I was thinking of my 250A. Looking at my RT I see the two bulbs that are in the very front of tach and speedo that's not covered by the bracket. Might still work with a little RTV to glue in place.
71 Z50 Minitrail
21 CRF300l Rally
21 CRF300l Rally
31 Jul 2021 13:48
#26
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=164840182742&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- Sneezles61
Thank you Mark! I ordered it!
Since the harness is off the bike, I'm cleaning up the connectors and applying electro grease.. I know my tinkerings are slow.. but they are steady! (:
Sneezles61
Sneezles61
01 Aug 2021 07:04
#28
