jetting for elevation change
  • RALPH
  • RALPH's Avatar Topic Author
jetting for elevation change was created by RALPH
Good Morning America. I'm looking for advice on jetting my 1980 DT-175. I'm giving the bike to one of my kids, and he lives 3827 feet lower than I do. I'll change the jet before putting the bike on a pallet, and add some just in case I miss it a little.
23 May 2021 05:45 #1
Replied by MarkT on topic jetting for elevation change
Is it stock?  Has jetting been modified from factory specs?  Why not just give it to him with factory jetting?  ...I guess unless you live at 12,122 feet and he lives at 8,295 feet
Otherwise you can use the Mikuni jetting calculations/charts which should be in the Mikuni tuning manual in the Tech Library...  pilot, main, and needle position may all need changing...  not just one jet.
23 May 2021 07:31 #2
Replied by JayB on topic jetting for elevation change
You don't mention what either altitude is.
If the motorcycle is completely stock including jetting then you probably will not have to make a change.
If it was rejetted for your altitude then change it back to stock.
You have to richen thing up if you are jetted for a high altitude and go to a significantly lower altitude, such as your case.
Here is some info from an old book, "Motorcycle Tuning For Performance":
23 May 2021 07:44 #3
JayB, If I remember correctly, that book has a RAD chart inside the back cover and the instructions in the text on how to use it to figure out jetting adjustments?
23 May 2021 08:19 #4
You remember correctly!  Here are the next 3 pages(16-19) and inside the back cover.  Since the site compresses the pictures, if these aren't readable I can send higher resolution pics to anyone.
23 May 2021 09:07 #5
  • RALPH
Replied by RALPH on topic jetting for elevation change
Thanks. Very informative. I appreciate it.
23 May 2021 11:27 #6
Replied by Mothersbaugh on topic jetting for elevation change
All this talk of percentages. I though the rule of thumb was change the jet one size for each 1,000' of elevation change, or each 10 degrees of ambient air temp.
Am I wrong? Not nearly as precise as the above, I guess, but that's what I thought I heard in Moab, Ouray, and other rides...
23 May 2021 14:59 #7
Just as a disclaimer, I have never rejetted for altitude or competitively,  So my opinion may be worthless!
  In this case I think it would be about half of the "one jet size per 1000 feet".  If you were running a Mikuni main jet of 270 at sea level, using your rule of thumb you would drop down to a main jet of 200 at 7000 feet.  That is about a 25 percent reduction in fuel delivery from the main jet.  According to the following pages you should reduce by about 9 percent to a 240 main jet and test from there.
  Sorry, I repeated the percentages!  I would always be more careful going leaner!
23 May 2021 17:51 #8
Sorry if the attachments are unreadable.  Here is a second try.And if you start at a 170 main jet, and your step sizes are 5, your "one size per 1000 feet" is not as far off.  I would still be careful going leaner.
The following user(s) Liked this Post: Rick C., MarkT
Last edit: 24 May 2021 17:55 by JayB. Reason: Corrected second page of inseted picture
23 May 2021 17:53 #9
