Margin for error on 6v voltage regulators
Margin for error on 6v voltage regulators was created by Gr8uncleal
On the face of it, this might seem like a daft question, but hey, if you don't ask, you don't find out!
In amongst a job lot of parts that I have just bought from the US (some of which I actually needed!
), were four used, 6v, single (yellow) wire voltage regulators. All are Stanley and came off Yamahas.
I have bench tested them using a 12v battery and the readings I got were 7v, 8v, 8v and 9v. My question is, will they all prevent the headlight blowing?
Also, what is the small screw on the front for?
Thanks very much.
Thanks very much.
Replied by RT325 on topic Margin for error on 6v voltage regulators
That's very interesting but i'm not sure i understand how you're testing it. I'm sure its just my problem how i'm reading the story, but it limits ac volts before it goes to dc after the rectumfrier. Lets know a bit more please. Screw does nout & probably just hold something inside to complete the circuit to the body as that's how it's earthed. That's all a total guess haha.
Replied by Gr8uncleal on topic Margin for error on 6v voltage regulators
12v battery direct to volt meter reads 12v. Tick.
6v regulator inserted between one of the wires from the battery to tester (doesn't matter which) and reduced voltages displayed.
So, the regulators are working, but enough to stop a 6v headlight bulb from blowing is the £5 question!
18 May 2021 04:56
I just googled for one & one i found led me right back to the forum. Not sure when but it had gone from ebay so saved the pic from the forum page as ebay link doesn't work. But what i was rambling about is it was on ebay as suit 6 or 12 volt which isn't correct. Prove me wrong please. But might explain why Gr8uncleal is testing it on 12. Come in ''Gr8uncleal" please.
A 12v battery is the only means I have of testing if the regulator is actually regulating as it should - cheaper than fitting them and watch as a series of bulbs blow as they are fed 18+ volts!
18 May 2021 05:02
I'm lost now lol as thought they're for AC only. Someone else's turn. Bed time here.
The following user(s) Liked this Post: MarkT, brigsy, Gr8uncleal
18 May 2021 05:03
Replied by MarkT on topic Margin for error on 6v voltage regulators
They are AC regulators, not DC. Might damage them connecting to DC? Not sure. DEET might know. I think I remember someone else trying to regulate the battery after the rectifier and destroying the regulator... not sure though.
Screw on original Yamaha regulator holds a component (transistor?) tight to the (heat sink) case. It's not an adjustment if that's what you're wondering.
DEET has a video on bench testing that might give some ideas or the later electro-tester had a regulator test function I believe.
18 May 2021 07:15
Thanks chaps.
Hopefully I haven't damaged anything!
18 May 2021 07:28
- msavitt
Replied by msavitt on topic Margin for error on 6v voltage regulators
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=124602532523&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- nhsteve
Replied by nhsteve on topic Margin for error on 6v voltage regulators
Just curious as to where you wound up mounting that? It is fairly sizable as I recall, when looking at them.
22 May 2021 07:02
