1975 AG100
- aussieag
1975 AG100 was created by aussieag
hey everyone, ive had my ag 100 bike for a few years my great grandfather gave it to me he couldnt get it running, i pulled the carby apart and cleaned it and put it back together. i can get it to run with the choke on but as soon as i turn the choke off it just shuts off, even when i adjust the screws, i have to hold the revs up a bit but as soon as theres any decent load on the engine it just dies
could anyone help me as i want to fix this bike up properly but i want to get it to where it with idle and ride around.
09 Aug 2020 04:09
- Swoop56
Replied by Swoop56 on topic 1975 AG100
You've almost certainly got a blocked pilot jet in the carb .
As it's one of the smallest jets in there , it blocks fairly easily , when left sitting for extended periods .
09 Aug 2020 14:04
- aussieag
Replied by aussieag on topic 1975 AG100
I pulled it apart today and cleaned it and it’s still doing the same thing are there any wires that could be causing the problem or could it be the wrong carby I’ll attach a photo
10 Aug 2020 00:12
- Swoop56
Carb should have an ID number , usually stamped on the flange .
10 Aug 2020 00:50
- aussieag
Is this the number?
10 Aug 2020 01:13
Replied by Gr8uncleal on topic 1975 AG100
Yes, I would say so.
336 is the model code for the 1972 LS3, also a 100cc two stroke single. I'll leave it to others to say whether or not it is the correct carb for your bike, as I know very little about them (I'm in the UK).
10 Aug 2020 04:58
- apex
- Content Contributor
Replied by apex on topic 1975 AG100
Still sounds like the pilot jet is plugged, it's the really small jet deep in a small bore right next to the main jet & jet setter. Are you sure that passage is clear?
If yes, maybe the reed petals are lifted, that could cause idling issues.
Allrighty Then
10 Aug 2020 15:24
- Swoop56
Check the pilot passage through to venturi is clear , as well as pilot jet .
10 Aug 2020 18:26
- aussieag
Do you have a photo of the jet so I can be sure I was looking at the right thing
11 Aug 2020 01:20
- Swoop56
Your carb should have an ID mark 49760
It looks like the carb you have on the bike isn't correct .
I have a list of specs , but probably not much point in giving them to you ,
until you can locate a replacement .
11 Aug 2020 01:47
