Kickbacks and Backfires
  • Brian Peech
  • Brian Peech's Avatar Topic Author
Kickbacks and Backfires was created by Brian Peech
So my DT360 has a new issue since I tried to start about 2 years ago. I'd appreciate help with the sequence to diagnose and isolate the problem.
cleaned carb, adjusted float, new gas. Running Rex's Speedhop CDI.
Here's what's happening:
-choke on.
-open throttle a bit
-kick, kick, kick, hard kickback.
kick, loud backfire in the exhaust.
kick, start. Runs fine.
Any ideas on how to go about taming the kickback and backfire? And in what order to approach this?
Thanks.
Last edit: 29 Apr 2020 09:45 by Brian Peech.
29 Apr 2020 09:05 #1
Replied by Gr8uncleal on topic Kickbacks and Backfires
I can't answer your question, but it might help others to if you could let us know if you are running points or CDI (a lot were converted to points). If CDI, original Yamaha or aftermarket replacement?
Thanks.
29 Apr 2020 09:29 #2
  • Brian Peech
Replied by Brian Peech on topic Kickbacks and Backfires
Ah yes, that is important. I am running the CDI from Rex's Speedshop.
29 Apr 2020 09:44 #3
Replied by mdscott on topic Kickbacks and Backfires
The DT360 has a decompression valve on the cylinder above the exhaust, if not working It will kick back. There’s a cable that connects the valve to the kick starter mechanism.It releases a small amount of compression so it kicks over easier
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
29 Apr 2020 09:45 #4
Replied by MarkT on topic Kickbacks and Backfires
Best to not open the throttle with the choke (enrichener) as it doesn't work as well with the throttle open.
I'd test the timing with a light when kicking it over... sounds like a timing issue to me. People have had mixed results with the Rex system.
29 Apr 2020 11:03 #5
Replied by Schu on topic Kickbacks and Backfires
My DT360 has a functional OEM auto compression release, but it will kick back if I open the throttle at all when kicking it over. I actually place my throttle hand to the left of the grip so I don't inadvertently open it up at all.
CT1B, CT1C, JT1, JT2, CT2, RT3, DT360A, GT80B, DT100B, DT125B, DT175B, DT175C, DT250B, DT400B, Z50
29 Apr 2020 12:12 #6
My DT360 with a VAPE (PowerDynamo) and the decompression valve working good it kick and starts very easy, usually two kicks.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
29 Apr 2020 12:36 #7
Does your 360 ever kick back?
29 Apr 2020 12:45 #8
No, does not kick back, like MarkT suggested, check the timing. Those decompression valves get gummed and don’t work properly. I will try to find a picture of one I took apart and rebuilt.
Do a search for” 1974 Resto, DT360”, it will be on that somewhere.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Last edit: 29 Apr 2020 17:53 by mdscott.
29 Apr 2020 17:41 #9
Replied by RT325 on topic Kickbacks and Backfires
First & only thought if it's backfiring in the exhaust & kicking back--is--The Flywheel key is Toast. Sorry but i haven't read the story very thoroughly just now.
Last edit: 30 Apr 2020 00:46 by RT325.
30 Apr 2020 00:45 #10
