Help with 71 DT-1F
- BigPete
Help with 71 DT-1F was created by BigPete
Brand new to this site. I recently acquired a 70 and 71 DT-1 that are factory original. However, they have not run in 25yrs. They were stored in a barn in the Nevada desert and seem to have no rust. I ordered a set of cables and despite telling them what I have they sent me a set with the wrong throttle cable; it doesn’t have the lead what goes to the oil injection. Ordered another throttle cable and it has the oilpump dongle but the cast-on lead end what goes into the carb slide is waay to big. It looks as if it’s for a brake cable. Plus the end that goes into the carb top has a threaded end with two jam nuts and will not fit the cap at the top of the MIKUNI carb. Is the correct cable available or am I going to need to modify this one? I’m working on the 61 DT-1F
16 Aug 2026 16:08
Replied by MarkT on topic Help with 71 DT-1F
KDI Reproductions has the correct cables.
That said, it sounds a little like you're trying to connect the oil pump cable to the carb?
16 Aug 2026 16:18
- Drac56
Replied by Drac56 on topic Help with 71 DT-1F
Lucky you..
I guess i need to go on some Barn crawl adventures.
I sorta read your message as Mark does..
2 very different areas of the bike after the split connection —> ( 2142626100 ) from the upper throttle cable, oil pump cable ( 2142632100 ), lower throttle cable (2142631200) ..
KDI .. most cost effective replacement.
16 Aug 2026 16:33
Replied by Ht1kid on topic Help with 71 DT-1F
Greetings from Tennessee
16 Aug 2026 21:20
- BigPete
Replied by BigPete on topic Help with 71 DT-1F
Thanks all you guys…got the correct parts en root….!
17 Aug 2026 09:35
