DT front wheel and brake hub
- Zedbed
DT front wheel and brake hub was created by Zedbed
Hello all!
I've just bought a front wheel for a DT. The wheel is 19" the brake drum is approx 150 mm. inside the drum below the Yamaha symbol is the number 22700.
My question is: is this a DT250,DT400 or either or neither!
Thanks in advance
Thanks in advance
08 Mar 2024 06:27
Replied by Gr8uncleal on topic DT front wheel and brake hub
Could you post a clear picture of the numbers cast on the inside? You'll need to use Imgur or similar.
08 Mar 2024 06:30
Replied by Ht1kid on topic DT front wheel and brake hub
Greetings from Tennessee.
08 Mar 2024 07:59
- Zedbed
Replied by Zedbed on topic DT front wheel and brake hub
How's that? did that work?
I see my photo didn't arrive, I'll have to wait for the web site to get repaired and then try again.
Sorry and all that !
- Schu
Replied by Schu on topic DT front wheel and brake hub
I’m thinking neither, because my DT250 and 400 both have 21 inch front wheels.
08 Mar 2024 09:03
- Zedbed
I read it somewhere yesterday that 19" was an option, but it didn't say which model.
The brake drum is a bit larger than the DT 175 and a wider rim (3.25 -19 tyre or tire in the USA!) .
My DT 175 has a 21"front wheel.
08 Mar 2024 09:30
Just had a ferret around on the CMSNL website and it looks like you might have a front wheel for a 1973 DT3/RT3.
Looks like that 227 hub was used on the enduro 250 and 360 bikes from 1968 to 1974 and the DT3/RT3 had a 19" front wheel. Looks like the 1974 DT250/360 had a 21" front wheel.
08 Mar 2024 09:56
