New guy from Colorado with an 1972 At2m
- Thanney
New guy from Colorado with an 1972 At2m was created by Thanney
Hey everybody! This is my first bike and I bought it as a project. I’ve found it hard to get information about the At2m bike and was hoping to find some other people who know a little more about the bikes on here. If so let me know!
right now I am trying to figure out a throttle cable. I found out that it was probably a y split cable that goes to the auto line pump and carb. Do y’all have any recommendations that may work?
- Thanney
Replied by Thanney on topic New guy from Colorado with an 1972 At2m
Also typo in subject I mean 1972
Replied by MarkT on topic New guy from Colorado with an 1972 At2m
Fixed your typo... you might check CMSNL as they have about the only AT2M/AT3M parts list I've ever seen online
www.cmsnl.com/yamaha-at2m-motocross-1973...model8416/partslist/
Yes, the cable is split and be aware some parts are different than the "Enduro" model like the seat, airbox, carb, and pipe and can be hard to find and expensive if you do.
It's rare to see one with the autolube intact.... Some of the manuals are available in the Tech Library here (AT2M and AT3M are very close to the same and might even be identical)
13 Oct 2023 10:57
- Thanney
You’re the best! Thank you so much. Seems like a nice community here.
13 Oct 2023 13:20
Replied by Ht1kid on topic New guy from Colorado with an 1972 At2m
Greetings from Tennessee
Yes the best forum lots of helpful people here
The following user(s) Liked this Post: Thanney
13 Oct 2023 17:12
- msavitt
Replied by msavitt on topic New guy from Colorado with an 1972 At2m
Hola from OC CA
13 Oct 2023 18:18
- asco
Replied by asco on topic New guy from Colorado with an 1972 At2m
I have a 1972 Yamaha AT2M and installed the oil pump that was originally on the bike. Because of the expansion chamber the oil pump cable itself had to have the rubber removed for clearance reasons. My bike was purchased by the original owner when he was 12 or 13 and needed to walk the bike home. I purchased all the cables from KDI Reproductions and everything fit well. You probably won’t find the air box and you will pay a fortune for the correct front fender. I sold mine and went aftermarket.
asco
asco
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
14 Oct 2023 03:01
