Yamaha dt175 dtb
- Spow
Yamaha dt175 dtb was created by Spow
Hi I am steve. I have a yamaha dt175 1976 that I am renovating. I am from WALES UK.
03 Sep 2023 11:42
- Spow
Replied by Spow on topic Yamaha dt175 dtb
Hi can anyone tell me where I can get a clutch kick pinion for my yamaha dt175 1976 . THANKS
03 Sep 2023 11:46
Replied by MarkT on topic Yamaha dt175 dtb
Please check your VIN. You mentioned "Dtb" in the heading which is a 1975 model. A 1976 "C" model has many different parts under the clutch cover compared to 1974/1975.
For example, the kick start driven gear is a part of the clutch basket on a 1976 model. So if you are looking for the kick gear under the center of the clutch basket for a 1976, you won't find it as a separate part.
Earlier models had the kick gear under the center of clutch basket as a separate part.
P.S. You cannot use a 1976 clutch basket on a 1975 without swapping a lot of other parts.
03 Sep 2023 12:24
- Spow
Thanks for a quick reply. Frame no 1G1-001256.The engine number is the same, any help would be much appreciated.
03 Sep 2023 12:46
- Visitor
Replied by on topic Yamaha dt175 dtb
Errian Davies in Wales, has a large amount of TY175 parts. TY clutch might well fit your DT............well worth checking. Think he is on Facebook?
03 Sep 2023 12:53
A 1G1 is not a US model and unfortunately most online parts books are for the US models.
Perhaps one of our members in a country that had the 1G1 will have a printed parts book and can help.
That said, it does look like the 1G1 was a 1976-77 model so it "might" be similar to the 1976 US DT175?
Here's a picture from a 1976 non-USA DT175, does yours have the kink in the frame tube where I drew the arrow? 1974 and 1975 US models had a straight tube there, no bend which is the easiest way to tell them apart.
On the clutch, the 1976 did not have a replaceable kick gear on the back of the clutch basket. (I believe there is a "525" on the clutch basket casting.) You'll have to replace the entire basket if yours is like #2 at this link. www.partzilla.com/catalog/yamaha/motorcycle/1976/dt175c/clutch
And yes, it looks to be the same as a TY175 basket as suggested.
Earlier models that had a replaceable clutch kick gear had a larger diameter clutch shaft so the basket and gear are not the same.
03 Sep 2023 13:50
- Spow
I have removed the clutch basket the numbers stamped on it are 525-16311-#c.1 .where can I get a clutch kick pinion gear from. Any help would be much appreciated.
04 Sep 2023 13:23
- Visitor
www.cmsnl.com/yamaha-ty175-1976-usa_mode...ear-comp_5251615000/
Looks like the gear not sold separate? You might find a complete NOS drum in Japan, but going to be pretty costly.
04 Sep 2023 23:47
- Spow
Hi I have been offered a dt 125 1976 clutch basket .does anyone know if it will fit .it has the same amount of teeth.?
05 Sep 2023 09:43
- Spow
Hi can you give me more information on Errian Daves please. You are spot on ty will fit the Dt175 1976
05 Sep 2023 12:22
