DT360A carb clamps
  • Trigbe
  • Trigbe's Avatar Topic Author
DT360A carb clamps was created by Trigbe
Looking for the clamps that attach the carb boot to the carb and airbox. Yamaha shows them NLA. I was wondering if any of the later models used a clamp that was close to the same size before I go to a hose clamp. Any recommendations would be appreciated.
Trig
04 Mar 2019 06:48 #1
Replied by Swoop56 on topic DT360A carb clamps
Check the part number on a site like Partzilla , and check the part number
into Ebay motorcycle parts . I'd be very surprised if you don't get a result .
With the part number , there may be a superceded number and original number .
Check them both , as NOS stock is more likely held with the original number .
04 Mar 2019 11:42 #2
  • Trigbe
Replied by Trigbe on topic DT360A carb clamps
Tried all of the above. The problem is Yamaha does not list clamps by adjustment range so no way to cross check other models.
Trig
04 Mar 2019 11:55 #3
Replied by MarkT on topic DT360A carb clamps
What are the diameters you need?
04 Mar 2019 13:51 #4
There are a couple on Ebay
# 362560438644 NOS Clamp
# 113598236575 Used clamp and rubber boot
NB The original part number is common to RT 1/2/3 so some members here could very well
have used clamps on parts bikes
04 Mar 2019 16:09 #5
Replied by Gr8uncleal on topic DT360A carb clamps
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=201819475647&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Right, just been into the garage to take a photo and do some measurements.
First up, I'm assuming that it's the identical clamps for each end of this hose/joint that you are looking for Trigbe?
Just to confirm, the part number was originally 308-14455-00, superseding to 90460-54062.
The external diameter of the hose is 2 and 1/8 of an inch (2.125"), maybe a smidge over.
The downside of getting aftermarket parts from 2Fast Moto is that they are black, whereas the originals were bare metal (see second picture nabbed off ebay).
I hope that this helps.
06 Mar 2019 03:31 #7
Replied by maraakate on topic DT360A carb clamps
Heya,
I'm also looking for these clamps as they are also used on the DT250A.  There's two from Canada, but I'm not interested in spending $30 shipped for two clamps to USA.  Does anyone know of aftermarket ones that will fit?  Being black instead of bare metal is OK.
10 Jun 2021 16:12 #8
