Cylinder jug, I,D. ?
- Blackhat250
Cylinder jug, I,D. ? was created by Blackhat250
I inherited a jug , [ its 397cc] its stamped 50000 on the other side [ where the Usual 1M2 etc is] the reed block orifice is much larger than the DT400,
what model is this off,
If you aint mixin gas " you aint haulin Ass
01 Jan 2016 14:52
Replied by RT325 on topic Cylinder jug, I,D. ?
guessing MX400B. Found a similar question just by googling & guy said his was 87mm i think which is 400 plus 1mm oversize. That'll make a quick DT if you squeezed some extra compression out of it--well-- plus pipe & carb & reed block & [where was i lol] Cheers if i'm right--never mind if i'm wrong. Someone will know for sure.
01 Jan 2016 16:07
- Blackhat250
Replied by Blackhat250 on topic Cylinder jug, I,D. ?
Superb , its a bit scabby , the reed block& boot are there too .
01 Jan 2016 16:20
- Enduronut
- Founder Moderator
Replied by Enduronut on topic Cylinder jug, I,D. ?
It's a 75/76 DT400 Enduro cylinder
Stock / standard bore size is 85mm
The following user(s) Liked this Post: Devin, Rick C.
Quite right, 400's are 85mm std not 86mm [senior moment-again]. Think my yz490 is 87mm without looking.
- Blackhat250
Its on 85mm. [standard bore] porting is more aggressive than my DT400 Jug & that inlet is massive compared to the DT jug, Mx400 then .
they are the same height , [ left barrel in picky is sunk into cushion, ].
- Devin
- Supporting Moderator
Replied by Devin on topic Cylinder jug, I,D. ?
Sorry.....its not an MX400, its a 75-76 DT400B/C (as Enduronut mentioned). The ports are more aggressive on the 75-76 DT400 B/C compared to the 77-78 DT400 D/E (likely due to EPA cracking down in the later years). The 75 MX400B has even more radial porting. I hope it helps.
The following user(s) Liked this Post: Enduronut, Rick C.
- Enduronut
- Founder Moderator
Thanks for the pictures Devin.
For those that don't know (trust) me . . .
I don't make a habit of commenting, unless I'm pretty sure I know what I'm talking about.
Most folks don't know that my heart pumps Yamalube !
The following user(s) Liked this Post: Devin, Rick C., Blackhat250
- FrankC
- Solution Contributor
Replied by FrankC on topic Cylinder jug, I,D. ?
I have heard 75- 76 DT400 are supposed to put out 5 more ponies than the 77-78?
02 Jan 2016 10:44
- Blackhat250
Good call "
,, funny that, I had the twinskhock in 1979. and then the Monoshock in1980, and the 400b would wheelie no problem, The 400d never,[ even in 1st gear] I just thought the 400d was worn out,[ 3rd owner by then ]
Why did Yamaha down tune the Monoshocks? ,
02 Jan 2016 10:56
