DT 400 Dieseling
  • tgill
  • tgill's Avatar Topic Author
DT 400 Dieseling was created by tgill
I have a '76 DT 400 that was just put back on the road after a long sleep and I noticed a lot of dieseling at low RPMs.  She bucks quite a bit in 1st gear before building speed.  What kind of adjustments should I be looking at?
Thank you,
25 Jan 2026 16:23 #1
Replied by Schu on topic DT 400 Dieseling
My 75 DT400 does the same thing. So I’ll be following along to see if you can sort it out. One thing I’ve done that made a noticeable improvement overall was replacing the needle and the nozzle in the carburetor. Many people said the big bore bikes have a substantial pulsation that wears out the needle and nozzle. It made such an improvement that I did the same for my DT250 with similar results. I’d love to do the same on my Dt360 but I cannot find a replacement nozzle.
25 Jan 2026 19:40 #2
  • tgill
Replied by tgill on topic DT 400 Dieseling
Thanks, and I remember reading that thread!
I wasn't sure that I used the right term as "dieseling" can sometimes mean running after shutoff.  What I describe is a bucking at low RPM's in gear.  10 MPH in 1st gear can be a rocky experience!
I'll check into a nozzle and needle.  Probably Ebay?
26 Jan 2026 18:16 #3
Yep you described it perfectly. I got mine thru DEET. But I have seen them on eBay as well.
26 Jan 2026 18:31 #4
Replied by Sneezles61 on topic DT 400 Dieseling
Just be sure to get mukini parts. All others are inferior.
28 Jan 2026 08:07 #5
Replied by MarkT on topic DT 400 Dieseling
Schu,what series is your DT360 needle jet?  164?
The 159 series is not identical but some have successfully used it to replace the 164.  Just get the same size (0-2, N-8, whatever it is.)
The following user(s) Liked this Post: Snglsmkr, AirborneSilva, Schu, Ht1kid
28 Jan 2026 10:26 #6
MarkT, you had previously shared that info with me and I saved it. You even provided a comparison photo with markups. Thank you very much. I plan to pursue it this spring and will let you how it works out.
28 Jan 2026 14:48 #7
Replied by RT325 on topic DT 400 Dieseling
Link a video through youtube if you can.
Only guessing as to why it running ratty off idle if i understood it--i'll go read again properly!!
But if the idle mixture is set too rich--like right in & should be out about 1.5--2 turns max.
If the needle jet & needle combo is worn it'll blubber rich & that's a reasonably comon problem with those in old age & high mileage.
If the choke is accidentaly left open--choke on--then it'll goes all up the creek especially after closing throttle then coming up again.
Also, if it lacks top end performance don't forget the exhaust & deep in the tail muffler.
Last edit: 28 Jan 2026 16:23 by RT325.
28 Jan 2026 16:02 #8
Replied by buckstrucks on topic DT 400 Dieseling
No amount if tuning seems to make a difference on mine. Compression is good, crank holds 5 PSI for an hour, carb is spotless, intake and exhaust are all stock. I can not get it to run cleanly at low throttle settings. If I jet it to run crisply at low throttle settings, it bucks, pings, bangs, and will occasionally hang idle when you let off. If I jet the pilot fat enough to reduce those issues, it blubbers and makes holding a steady speed near impossible. I've had pilots from 40-65 in it playing around. I've tried 2 different OEM carbs. It only runs good on the needle, and starts breaking up or goes flat at 5000 under a heavy load full throttle in higher gears.
The stock air box also seems like a major restriction. With a UNI cut down to be single layer and the snorkel out it pulls harder throughout the rev range, and right up to 6000 RPM with a 175 main jet. With the snorkel and a lightly oiled stock filter, I had to go down 3 main jet sizes to 160 to get it above 5000RPM, and it still falls flat on its face past that under a load.
I am convinced that the cylinder head design just sucks. I will probably be sending my head and cylinder out to Klemm Vintage for the 91 octane mod and a mild porting touch up. I will probably have them match the head shape and cylinder bore to a new Woosner or Weisco piston.
31 Jan 2026 19:02 #9
Replied by AirborneSilva on topic DT 400 Dieseling
Buckstrucks, I'd like to know how it turns out with Klem, I contacted them a few months ago about their blueprint service, they said they quit that and were concentrating on something else (which I can't remember).
31 Jan 2026 19:52 #10
