Kill switch ?
- ZEFER
Kill switch ? was created by ZEFER
I’ve been fooling with a 74 DT 250-A
basicly just cleaning 40 plus years of baked on dirt..oil …dirt with oil..the bike is-was a 2 nd kick machine before it got cleaned..nothing was disturbed or modified.. I did install a new front brake light switch.So I was in the headlight to plug new switch. I had the throttle and right side switch housing..so I took it apart and found it not connected to anything. It is a black wire with a white trace. It now is just hanging not hooked up…the kill switch grounds the coil ? So I should have spark without it being hooked up ? I
29 Dec 2025 12:10
- Swoop56
Replied by Swoop56 on topic Kill switch ?
No . The kill switch only grounds the coil when activated .
With it's wiring disconnected , everything will work normally ,
but obviously it won't be killing anything if operated .
29 Dec 2025 12:16
Replied by MarkT on topic Kill switch ?
With the black/white wire hanging free you should have spark.
29 Dec 2025 17:26
- ZEFER
Replied by ZEFER on topic Kill switch ?
Thank you guys. I did get it running after getting the Black white trace wire out of the switch housing…so here’s what’s puzzling the wire wasn’t attached to anything and it had a dab of solder on the end…where is that supposed go once inside the housing ?
30 Dec 2025 15:05
Goes to the on-off switch inside the housing.
31 Dec 2025 08:42
- ZEFER
What does the black wire get soldered too in the switch housing
06 Jan 2026 06:59
