DT175 piston & rings search
  • AT3CT31973a
  • AT3CT31973a's Avatar Topic Author
DT175 piston & rings search was created by AT3CT31973a
Hi there
I have a Yamaha DT175A 1974 twin shock model and I was wondering if anyone can answer me this question.
It has a Dykes piston as standard, this type has a stepped down piston ring crown that uses a 'L' shaped top ring.
Piston 2nd over 443-11610-20
Can I use a later type of piston that does not have the stepped  down top ring ?
Thinking of the later 1977 onwards mono shock version.
Obviously the piston pin to crown height needs to be identical & other measurements.
The Dykes type piston & rings are  hard to find nowadays.
Any help much appreciated
12 Dec 2025 07:37 #1
Replied by Tinkicker on topic DT175 piston & rings search
Ty175 had the same piston and are much more commonly advertised...
12 Dec 2025 18:38 #2
