Dt360 won’t rev out
  • john.lockwood5@bigpond.com
  • john.lockwood5@bigpond.com's Avatar Topic Author
Dt360 won’t rev out was created by john.lockwood5@bigpond.com
I have fitted a Rex RK8 ignition system to my DT 360a, it runs well.
everything is standard specs as from the factory,
however it won’t rev beyond 6100-6200 in any gear.
mixture throughout the full range is good, compression and leak down tests are also good. Gearing is as original specs.
I thought maybe Rex put a rev limit on the system?
any suggestions?
04 Oct 2025 22:30 #1
Replied by Gr8uncleal on topic Dt360 won’t rev out
You could try removing the airbox lid to see if that helps.
Exhaust might be a tad blocked?
I think I've read that they don't rev much beyond 6k normally, although I might have that wrong.
05 Oct 2025 01:42 #2
Replied by treeves on topic Dt360 won’t rev out
I have a Dt 360 that I have had over 50 years and 6000 rpms is about it.
05 Oct 2025 08:53 #3
Replied by MarkT on topic Dt360 won’t rev out
A direct quote from the 1974 issue of Cycle magazine test of the DT360a:
"Attempting to spin the engine above 6000 rpm for more power is futile....."
The following user(s) Liked this Post: Snglsmkr, Schu
05 Oct 2025 10:37 #4
Replied by john.lockwood5@bigpond.com on topic Dt360 won’t rev out
The magazine is saying 6000 is the power limit, no use revving further as there is no increase in power.
The complete exhaust is NOS
07 Oct 2025 22:45 #5
