Weird leak on crankcase
- ikaika-spar10
Weird leak on crankcase was created by ikaika-spar10
Hello all, im having a weird leak on the left half of my crankcase that I just cant find a seal for or anything I can replace to stop the leak, im at the point of using jb weld to seal it but figured id ask here first. The leak is coming from right between the shifter and drive sprocket, there is this little protruding spot on the case that looks like it should have a seal or something on it but nothings there and it just leaks trans oil out. Ill try to upload an image but other then that I don't know how to describe it better. Thanks all
29 Sep 2025 11:12
- Swoop56
Replied by Swoop56 on topic Weird leak on crankcase
Bike model ?
29 Sep 2025 13:02
- ikaika-spar10
Replied by ikaika-spar10 on topic Weird leak on crankcase
74 dt250a
29 Sep 2025 13:12
Replied by MarkT on topic Weird leak on crankcase
I think that model had at least one shift fork support shaft that was through-drilled through the case and sealed with a cap.
I know the shift drum was too.
See if part #19 in this diagram makes sense.
www.partzilla.com/catalog/yamaha/motorcy...974/dt250a/shifter-1
29 Sep 2025 15:00
I found a pic. It's basically a small "freeze plug". A good auto parts store should have one.
29 Sep 2025 15:09
- ikaika-spar10
Yes! that is exactly what it is, thank you all very much for the help. I am still new to motorcycles in general so this is very helpful. I just replaced the shifter seal and installed new clutch plates and springs so hopefully i can ride again soon. Thanks again all
29 Sep 2025 21:29
