Dt360a decompression valve removal
- john.lockwood5@bigpond.com
Dt360a decompression valve removal was created by john.lockwood5@bigpond.com
Anyone know if you can remove the decompression valve installed in the engine
while the engine is still in the bike. If so, how do you get at it to remove it?
As a side note, compression is 145-150psi, is that good?
Replied by Gr8uncleal on topic Dt360a decompression valve removal
I'd take a punt and say that you can remove it without even taking the cylinder off (I think it threads in like a bolt). However, I'm not sure that you can clean out the hole properly without taking the cylinder off.
23 Jul 2025 23:18
Replied by john.lockwood5@bigpond.com on topic Dt360a decompression valve removal
Problem is getting to the bolt, which is part of the valve, to remove it
23 Jul 2025 23:35
The whole thing should dismantle in sequence from the front. Take photos as you go!
24 Jul 2025 00:15
- Sneezles61
Replied by Sneezles61 on topic Dt360a decompression valve removal
THATS on my to do list for this winter, so I’ll follow along..
24 Jul 2025 05:15
