DT360
- jsmith6752
DT360 was created by jsmith6752
I want to purchase a new carb cap for my mikuni carb. I want to go with a treaded cap on the top. How do I decide which one to get? There is a lot of different ones out there. thanks
16 Jun 2025 17:53
Replied by MarkT on topic DT360
Are you still struggling with throttle cable elbow?
When you mean "threaded on top" are you talking about the hole the cable goes through?
The caps are fairly universal for each body size... what is the OD of the threads the carb top screws onto? I will check to see if I have an original elbow for the stock cap or a cap with threads for the throttle cable fitting instead of the hole the stock cap has.
16 Jun 2025 19:28
- jsmith6752
Replied by jsmith6752 on topic DT360
I will check tomorrow. The cable has been back to HVC trice already. They had me send in the whole cable with the hand throttle and carb. For some reason the lower cable has a fitting that can come apart. When the bike turns left or right the cable pops apart. There is no reason to have that fitting at all. I ordered a new fitting that threads into the top of the carb. That's why I need a new cap that is threaded. I will try to send some pics thanks
16 Jun 2025 19:57
- jsmith6752
my mikuni carb is dripping gas out of the small fitting directly on the bottom of the bowl. Any thoughts ? On the bright side it now runs.
17 Jun 2025 06:54
- jsmith6752
17 Jun 2025 07:32
- jsmith6752
sorry can't add pictures
17 Jun 2025 07:32
- jsmith6752
top of the carb with the cap removed is 38.6
17 Jun 2025 09:23
- jsmith6752
what carb do I have? It's stock. I need to know to order a new cap?
17 Jun 2025 09:25
- pabdt
Replied by pabdt on topic DT360
JSmith, you might want to consider learning to post pics. What are the numbers on the choke boss? Its on the boss where the choke plunger is.
1. The elbow has an "E" clip on the inside of the cap to allow it to rotate 360 degrees.
2. The elbow has threads only on cable side. I just installed an HVCycle cable on mine.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
- jsmith6752
it's telling me picture hosting is not available HVC cycle tells me the cable is fine.
17 Jun 2025 15:13
