Decompression cable boots
- Akhddeluxe05
Decompression cable boots was created by Akhddeluxe05
Does anyone know if if you can buy new rubber boots for decompression cables any sources? I'm actually looking for the boot/cover that goes into the crankcase the other rubber cover the the front of the engine is good
Replied by Gr8uncleal on topic Decompression cable boots
Yes, it looks like KDI do them.
The tab is on the right hand side of the page, but I have attached a link for you.
275-12278-00
275-12278-00
The following user(s) Liked this Post: Buggin
27 May 2025 07:15
Replied by MarkT on topic Decompression cable boots
I also have a brand new original Yamaha cover in the bag if you want OEM,
$45 shipped in the USA
27 May 2025 07:33
- Akhddeluxe05
Replied by Akhddeluxe05 on topic Decompression cable boots
Thanks but im looking for the opposite end that goes into the crankcase
Thanks for editing your first post...
I've never seen that boot specifcally. I'm not sure offhand how big the cable boot needs to be but member DEET might have them?
Also Mikuni distributors like Niche Cycle have boots for the throttle cable that might work? www.nichecycle.com/vm26-46-rubber-cap-ca...uster-by-mikuni.html
27 May 2025 09:07
This is the one on my DT360A. I would imagine that it comes as part of the cable itself.
Maybe someone has/had a broken cable that they can remove the boot from?
- Akhddeluxe05
Yeah that's what it seems I have to find. Thank You
27 May 2025 11:27
Those cables are a bit of a unicorn from what I've seen.
Again, check with DEET. He makes and has some of the harder to find parts and I think he used to make decompression cables and still might? I got an early headlight beam switch boot/grommet from him a few years ago that isn't available anywhere else.
27 May 2025 11:42
- john.lockwood5@bigpond.com
Replied by john.lockwood5@bigpond.com on topic Decompression cable boots
How hard is it and how do you go about replacing the decompression cable on the DT250/360 ?
28 May 2025 00:08
- Akhddeluxe05
Not sure as I am in the process of rebuilding my engine. A suggestion the shop manual is available on this site for download. And that is very helpful to have.
28 May 2025 08:31
