Mikuni VM24ss twisted slightly
- DTTimClark100860
Mikuni VM24ss twisted slightly was created by DTTimClark100860
Hi again. ……I’ve now fitted my carb back on my DT175B bike and as before I removed it it’s slightly twisting to one side due to the throttle cable inlet touching the exhaust !
Will this effect the carbs function ?
many thanks for any reply’s ( I can’t seem to answer back )
03 Apr 2025 01:57
- Tinkicker
Replied by Tinkicker on topic Mikuni VM24ss twisted slightly
Anything touching the exhaust is not desirable. In my line of work, the minimum air gap between exhaust and say a pipe or cable is usually 19mm. Of course bikes being a little more compact may run things closer, but touching, no. Something is not routed correctly.
Note... Some cables have a wire spiral around them to create a small air gap if they run close to hot parts.
The following user(s) Liked this Post: DTTimClark100860
Replied by MarkT on topic Mikuni VM24ss twisted slightly
If I remember correctly should have a 45 degree elbow fitting in top of carb to angle cable immediately as it exits top of carb and a relief dent in exhaust for cable clearance.
It's a tight fit but I don't remember ever having to angle carb? Wondering if wrong throttle cable is installed or elbow is missing or something.
03 Apr 2025 06:50
- goatboy56
Replied by goatboy56 on topic Mikuni VM24ss twisted slightly
From my 1976 DT175c
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
The following user(s) Liked this Post: MarkT, Ht1kid, DTTimClark100860
03 Apr 2025 07:41
Replied by RT325 on topic Mikuni VM24ss twisted slightly
I'm assuming it's angled to the left. If it's not leaking out the overflow, breather at the base if the bowl when on the side stand/kick stand then she'll be ok. Mind you the breather might be central but anyway.
03 Apr 2025 13:42
