DT175B rack mounting
  • Wrench66
  • Wrench66's Avatar Topic Author
  • Content Contributor
DT175B rack mounting was created by Wrench66
Hi all, question for the group.....when installing a rear rack on a DT175B do the upper rear shock bolts go straight through the rack OR is there a special bolt with threads sticking out that the rack attaches to (like the earlier CT1 have)?
The parts list online only show a regular bolt but I wanna be sure.
thanks!
-- Ray
Nothing makes me smile like the smell of Blendzall green label ;)
22 Mar 2025 15:34 #1
Replied by Schu on topic DT175B rack mounting
On mine the upper rear shock bolt goes straight thru the rack bracket which is sandwiched behind the hex head on the bolt. It does not have the special bolt like those on the older CTs.
22 Mar 2025 16:54 #2
