1976 Yamaha Dt250 no spark help
- Malti
1976 Yamaha Dt250 no spark help was created by Malti
I am new to post and would appreciate help, so bought this Yamaha Dt 250 C model year 1976 and no spark at all took magneto apart and found a few issues with the wiring on the coils, the condenser and contacts are wired in series together. Cant find a proper wiring diagram of how they are wired, please
21 Mar 2025 09:50
- Oldbikenut
Replied by Oldbikenut on topic 1976 Yamaha Dt250 no spark help
With no spark issues I always start at the most basic things first, check the spark plug, plug cap, coil, points and so on. You didn’t mention that you checked these things is why I mention them
1971 RT1B-360
1971 Honda Trail 70
1972 Kawasaki S2 350
1975 Ossa MAR 350
1978 Honda Trail 90
1983 XT250
1984 Honda XR250R
1971 Honda Trail 70
1975 Ossa MAR 350
1978 Honda Trail 90
1983 XT250
1984 Honda XR250R
21 Mar 2025 12:28
Replied by MarkT on topic 1976 Yamaha Dt250 no spark help
I'm a little curious how you know that you "found a few issues with the wiring on the coils, the condenser and contacts are wired in series together." When you don't have a diagram?
Because what you're saying about the way it's wired sounds pretty correct to me. Could it be possible you don't understand how the system works?
I'm not aware of anything but a basic generic ignition diagram in almost all the older service manuals in the Tech Library. You might see if you can reach out to member DEET as he's rebuilt a lot of magnetos and might be able to answer questions.
That said, no spark on the points magnetos is almost always something simple like cleaning the points, sometimes a bad condenser but I avoid changing that unless needed as new condensers sometimes suck these days.
The only real exception I've come across to the "something simple" rule Oldbikenut mentioned is if there is physical damage... but that's usually pretty obvious.
The following user(s) Liked this Post: Ht1kid, Oldbikenut
21 Mar 2025 14:15
- automan
Replied by automan on topic 1976 Yamaha Dt250 no spark help
condenser and points are, or should be in parallel
i.e. condenser "shorts" points
In an electrical sense, technically it's correct that the single wire condenser itself is in parallel with the points when condenser case is grounded.
From a "visual" sense, most people in my experience will call the magneto ignition wiring "in series" as the "power" wire goes from stator windings to condenser to points like a daisy chain of components wired in series.
23 Mar 2025 09:09
