Front brake switch
  • john.lockwood5@bigpond.com
  • john.lockwood5@bigpond.com's Avatar Topic Author
Front brake switch was created by john.lockwood5@bigpond.com
Does the switch simply push into the brake lever holder on the DT360a, or does it turn when in?
If so, what actually holds it in place as mine seems to be pushed out by the lever when operated.
28 Feb 2025 22:23 #1
Replied by Gr8uncleal on topic Front brake switch
There should be one or two small tangs on the switch body. There will be at least one corresponding hole on the brake perch with which the tangs line up, and the tangs depress on entry, then click out once fully in - this is what holds the switch in position. To remove, you need to depress the tangs and pull the switch out.
If the tangs are just flattened, gently pry up with a small flat blade. If they are missing (ie snapped off), then you'll need a new switch.
28 Feb 2025 23:49 #2
Replied by pabdt on topic Front brake switch
I recently put one on my 125 and 360. Don't recall a twist being required. Recommend clean up the perch well before install.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
28 Feb 2025 23:54 #3
