Things
- UTBMXCruiser
Things was created by UTBMXCruiser
I'm looking to get my DT250B running that I've owned for 15 years without messing with it. 100% complete bike except the carb.
What is a good source for quality fork seals?
Has anyone ever tried a 78 DT400 34mm carb on this bike. Someone had put a 76 YZ125 carb (30 or 32) on there before I bought it and just left the oil pump hose hanging. I have a few of the DT400 carbs laying around and instead of hunting down a stock 498 carb I'd like to see if I can get one of those to work.
Anyone know of a better source than Hot Foot Moto for intake manifolds? The ones I've bought in the past has been a bit shady on quality. I bought a repro air boot this morning and will need a manifold. Both are wasted.
I'm going to do a leak down test and see where I'm at with the motor before I start tearing it down.. More to come.
What is the latest effective way to remove rust from inside a fuel tank?
86 YZ250S, 84 RZ350L KR, 82 IT465J, 81 YZ465H, 81 ZIT465H, 79 DT250F, 78 DT400E X 2, 78 DT175E, 77 YZ400D, 76 Bultaco 250 Pursang Mk 9, 75 DT250B
- pabdt
Replied by pabdt on topic Things
check ebay. I saw an OEM Yamaha fork seal for $14,new. There are others there too. partzilla $44 ea
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
24 Sep 2024 20:28
- Wessi
Replied by Wessi on topic Things
Where are you located? I have 2 good used origin carbs for the 250B from 1975.
I´m living in Germany.
25 Sep 2024 04:27
- UTBMXCruiser
Replied by UTBMXCruiser on topic Things
Thanks, you know I hate replacing fork seals only to have them in bad again in a fairly short time. Not all seals are created equal.
25 Sep 2024 05:06
- UTBMXCruiser
Utah USA is my location. I will keep what you have in mind. I do want to explore that larger carb idea but I'll certainly need to re jet a 34. May be in the ballpark. I may put a down pipe on it and explore reworking the airbox for more air flow. Maybe a YZ250C top end with that down pipe. All that would be a project looking for over 30 horse. A flat track motor if you will.
25 Sep 2024 05:21
