is this the correct headlight rim DT 360?
  • Gerryz
  • Gerryz's Avatar Topic Author
Can anybody verify if this is the correct headlight rim for a DT 360A / 1974?
imgur.com/a/Zbss6br
17 Sep 2024 07:11 #1
Replied by Gr8uncleal on topic is this the correct headlight rim DT 360?
Looks like it might be.
The 1974 models had a possibly one year only headlight, where the mounting screw for the rim to the bowl was on the left side, as you sit on the bike - all of my other Yamahas from the same period (and I have a fair few!) had the screw on the right.
EDIT - looks like I was wrong on the one year only point, according to CMSNL.
I might have a chance later on to check a spare that (I think!
) I have.
Last edit: 17 Sep 2024 08:28 by Gr8uncleal.
17 Sep 2024 08:02 #2
Yep, here are some images of mine - note how close the mount plate is to the beam adjusting apparatus.
Diameter from outer edge to outer edge of the outer ring is approximately 160mm.
Do you have a good lens, then?
Last edit: 17 Sep 2024 08:23 by Gr8uncleal.
17 Sep 2024 08:20 #3
  • Gerryz
Replied by Gerryz on topic is this the correct headlight rim DT 360?
Thanks for the fast comments :)
As this is the right rim I have to look for a good lens now. The bike came without a lot of parts…. also a lens :(
17 Sep 2024 09:08 #4
A long shot I know, but it might be worth looking out for a European headlight for your bike. A copy of the relevant page of the Euro model parts list is attached.
If you do find one, a tweak might be needed to some aspects of the wiring (I haven't looked into this).
The following user(s) Liked this Post: Gerryz
17 Sep 2024 10:17 #5
Replied by pabdt on topic is this the correct headlight rim DT 360?
Gerry, is that a YHA125 bucket? My rim looks exactly like what you have posted.
I picked this bulb up on ebay, but I guess niche cycle must sell it.
Niche Cycle Bulb for DT360
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
Last edit: 17 Sep 2024 23:24 by pabdt.
17 Sep 2024 23:24 #6
  • Gerryz
Don‘t know if this is YHA125, got. it in a seperate box with the DT360…. Seems that is the original one.
18 Sep 2024 08:36 #7
Yes, YHA-125 for the DT360A.
If you want to widen your options, pretty sure that the RD125/200 headlight and bowl is the same size, so you could find one, paint it silver and fit a 6v bulb (if you haven't converted to 12v).
18 Sep 2024 08:48 #8
  • Gerryz
really nice book....
18 Sep 2024 11:46 #9
