1975 DT400B crankshaft o ring
  • Akhddeluxe05
  • Akhddeluxe05's Avatar Topic Author
1975 DT400B crankshaft o ring was created by Akhddeluxe05
So what side of the crankshaft does the o ring go I'm thinking the long shift side right side. Parts diagram shows opposite side. Also manual stated insert shim when installing crankshaft, I don't recall a shim and parts diagram does not show a shim
Last edit: 24 Aug 2024 12:37 by Akhddeluxe05. Reason: Double posted
24 Aug 2024 12:35 #1
Replied by RT325 on topic 1975 DT400B crankshaft o ring
Oring goes as in the drawing. Gear has a recess that traps it & squashes it to seal on the shaft
With the shim, if none came out of yours & none shown here in the pic then i'd go with that. Think those motors had a slight step to allow for not having a shim.
See what others say that are more familiar with the 400.
images.cmsnl.com/img/partslists/yamaha-d...gyau1068a-6_f384.gif
www.cmsnl.com/yamaha-dt400-1975-usa_mode.../partslist/A-06.html
24 Aug 2024 15:15 #2
Replied by MarkT on topic 1975 DT400B crankshaft o ring
Shims can get stuck to crank or bearing by "stiction", not noticed, and then lost.
I'm not sure when the 400 went to no shims but it would be good to trial assemble by slipping the crank into right side case install the gear/spacer and snug the nut.  If crank had and needed a shim and it's missing, normally the crank will rub on the case when nut is tightened.  Best to find this out before final assembly!
Don't ask me how I know!
If you need a shim, DEET might have them.
The following user(s) Liked this Post: RT325, Snglsmkr, Ht1kid
24 Aug 2024 16:42 #3
& the conrod should be in the center line of the cases or close when assembled although the shim thickness wouldn't make much noticable difference to 'that'-- if it has one.
24 Aug 2024 17:34 #4
Replied by Eflrr96 on topic 1975 DT400B crankshaft o ring
O ring goes on the right, on the inside end of the drive gear off the crank. I just used the same shim that was in the bike to begin with.
I’m either livin’ the dream or dreamin’ of livin’!
30 Aug 2024 16:35 #5
