Searching for the correct rubber bearing
  • Gerryz
  • Gerryz's Avatar Topic Author
Replied by Gerryz on topic Searching for the correct rubber bearing
Sizes are the same (diameter 23 mm, length 23/25 mm) but one with 8 mm bolt and one with 10 mm bolt. I will check the sources, thanks for your help!
P.S.: is uploading from fotos still out of order?
28 Aug 2024 00:26 #11
Replied by Gr8uncleal on topic Searching for the correct rubber bearing
Photos need to be uploaded via a third party host such as Imgur.
28 Aug 2024 00:31 #12
Replied by Moto36 on topic Searching for the correct rubber bearing
Try ebay for universal shock absorber bushes,I have used them for many things in the past.
28 Aug 2024 02:11 #13
  • Gerryz
Found one which is 10 mm longer and will cut it on my lathe.
28 Aug 2024 03:33 #14
Replied by RT325 on topic Searching for the correct rubber bearing
Be sure to leave the center bit at length to fit & the stay bar & shorten the outer a bit more.
Sorry i'm sure you know what ya doing. Shut up 'Me'.
28 Aug 2024 04:38 #15
  • Gerryz
I have the original measures ;) Thx!
28 Aug 2024 04:47 #16
