Clutch basket DT 250 different vs DT 400?
  • DiggerJJ
  • DiggerJJ's Avatar Topic Author
Hi all,
I‘m rebuilding a spare motor for my DT 400 Type 513. currently I‘m a little bit confused about the clutch basket, I tried a basket from a DT 250 Type 512 but it does not fit with the primary drive - which has 24 teeth (should be correct) and which I bought on EBay.
The primary drive from a DT 250 type 512 has 23 teeth and the spares number for the clutch basket (correct: Primary Driven Gear Comp.) are different between DT 400 and DT 250. Could be that I have to use a clutch basket from a DT 400?
Here in Germany some guy mentioned it has something to do with the clutch gear wheel and the Primary gear which have been „married“ as a pair when the bike was build at Yamaha - there is always a number written / welded in on both wheels by hand. The clutch baskets should fit for both types…
How to go on?
27 Jun 2024 08:33 #1
Replied by MarkT on topic Clutch basket DT 250 different vs DT 400?
DT250 and DT400 of that era have different primary gear ratios.
DT250 is 23/65
DT400 is 24/64
So you cannot use a DT250 clutch gear on a DT400 as it has one more tooth and would be too big.
27 Jun 2024 09:40 #2
  • DiggerJJ
Replied by DiggerJJ on topic Clutch basket DT 250 different vs DT 400?
Thanks a Lothar the ratios - that’s what I thought but I was not sure
Kind regards
Jan
27 Jun 2024 09:52 #3
  • DiggerJJ
…thanks a lot
27 Jun 2024 09:52 #4
Replied by RT325 on topic Clutch basket DT 250 different vs DT 400?
What am i missing or not reading. Can you change the both clutch & crank gears as a matching pair.
27 Jun 2024 14:46 #5
RT325, I'm not aware of the crank stub differences, if any...  (I doubt there are any).  So I don't see why you couldn't use both gears from a 250 on a 400?
27 Jun 2024 21:00 #6
  • DiggerJJ
That‘s what I was thinking of for a moment - to look for a primary drive from a DT 250. Transmission will be little different due to the one tooth I guess.
At least I ordered a used DT 400 clutch basket in the US on EBay.com - to stay at the original build. Here inGermany the old twinshock DT‘s are very seldom…
27 Jun 2024 21:48 #7
