DT 400, throttle cable
Replied by DEET on topic DT 400, throttle cable
Did you contact HVC to ask about it?
They are the ones making the statement that they fit both bikes.
24 Jun 2025 08:54 #11
Replied by deux_smoke on topic DT 400, throttle cable
Haynes, I've got the Yambits cable working pretty well. I'm able to bottom out my slide, but it seems like the lower oil pump cable is a bit long. I've got that adjusted out as near to unthreading from the case cover as I dare go. I may try to find a longer adjusting nut for a tad more pull. The other option would be to have a custom cable set made by Barnett or Motion Pro.
24 Jun 2025 10:07 #12
  • pabdt
  • pabdt's Avatar
  • Platinum Member
  • Platinum Member
Replied by pabdt on topic DT 400, throttle cable
This might work.  Soldier on.   Make your own Generic Sleeve 3mm OD 1.5mm ID   custom length.
1969 Yamaha CT1 175
1974 Yamaha DT125A
25 Jun 2025 01:36 #13
Not bad. I'm thinking a slightly longer coupling nut like this (I'll figure out the size/pitch) will work to stretch the cable and allow me to get the oil pump wide open when I'm on the the throttle.
?crid=16CLSQT4L4QL8&dib=eyJ2IjoiMSJ9.K3lh9AWnNnz1fUdOiwDOaMLfgjtlskmPMz979FK0mrQY2WRzJJ7x02L6tIqgOKJTtDP3vRFEbKYFPV2DLaN0lma6a2f7RsHOAp9mqlOmNoy_1oZVL7os2fKMx8UBSO6jwVhPlAGReqiVY4nuxBvKSigC0gy8bEPVG8lO1HipjpUn9fzpG0zFBBfHAaw0y6BXKbY1_&dib_tag=se&keywords=m4+coupling+nut&qid=1750862192&sprefix=m4+coupling+nut%2Caps%2C168&sr=8-4
25 Jun 2025 07:42 #14
Sorry, looks like that link isn't working.
TOPPROS M4 X 0.7 -Pitch 12mm Length Hex Width 7mm Metric Hex Coupling Nut 304 Stainless Steel Rod Coupling Nuts( Pack of 20): : Industrial & Scientific
25 Jun 2025 08:14 #15
